Sat, Sep 21, 9:03 PM CDT
Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
Subject: Having some trouble with adding decal textures
ghst32 ( ) posted Tue, 18 March 2003 at 4:15 PM · edited Sat, 21 September 2024 at 8:38 PM
I have an object with a texture and a bumpmap. I want to add a small decal in a specific place on the object over top of the texture that is already there. The decal is a picture, a .gif i think. Im having trouble combining the original texture with the small decal in the material library. any suggestions of things to try would be helpfull, thanks.
Quest ( ) posted Tue, 18 March 2003 at 8:08 PM
Duplicate your object and scale the duplicate by a very small amount so that it is barely larger than the original and apply your decal to it. Make sure the invisible portion of the decal is black and make a black and white image using the original decal image but the inside visible area is completely white and use that image as your alpha channel.
Quest ( ) posted Tue, 18 March 2003 at 8:13 PM
P.S. Group the two objects together
haloedrain ( ) posted Tue, 18 March 2003 at 8:59 PM
or to get the same effect as the above image you could use only one cube and put a texture in channel A and a picture (such as the smiley face above) in channels B and C
ghst32 ( ) posted Tue, 18 March 2003 at 9:01 PM
Yes that will work I think, thanks alot.
