Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
heyas; DONT TOUCH THE CR2! :) okay, you have hair. you load the obj into your modeller, and flip it. now, take the original cr2 and point it at your flipped hair, and it will work fine. now, the MORPHS won't work, so take those out. if you can export those and mirror those and put them back on, more power to you! but that is what you'll have to do. (note: that might work better if you export the object from poser to use as the base to flip, intead of the real base. but transferring morphs is an adventure you'll have to have for yourself ;) ) all the cr2 does (besides store the morphs) is tell the thing where to bend. even if you flip the geometry, it will still bend in the same spots.
Jim, that's one solution, but not preferable to me. Some of my textures have features on one side but not the other...moles, tattoos, etc and they are where they have to be already. Surely there must be away to make it happen. So far, most of the hairs where I need to modify them are fine as Hr2s...seldom a need for conforming hair IMO. -WTB
heyas; the cr2 is working, but there's something up with the geometry, if that's what happens. you're sure you didnt MOVE or SIZE the hair when you flipped it (or when you imported/exported it to your modeller), right? you have all the group names still intact, right? all the same as they were before? you didnt end up with groups as materials and materials as groups or weird spaces or punctuation or strange capitalization in your groups? if you really wanted, you could import the flipped obj and make it an hr2.
yeah, what bloodsong said above, when you mirrored, did your new obj still have groupings? just do the hr2 thing ;) import the new obj, place it on the figure's head, save in hair folder, make your own morphs. depends on how complex the original hair model was i guess...
[ Store | Freebies | Profile ]
a sweet disorder in the dress kindles in clothes a wantoness,
do more bewitch me than when art is too precise in every part
I'm joining this one in the middle, but I've been wondering about this too. I guess my question is even more basic: how do you mirror the hair obj? Does it have to be in a program other than Poser and then imported? Or is there a way to do the flip right in Poser? And yes, WTB, in case you're wondering, this does have something to do with my Indiana Jones figure I talked to you about in an earlier thread, but I've been wondering about it in general too...;-) -Mike
heyas; jim, the conforming/figure hair may have several groups to match the head/neck/chest, and especially if it has posable braids or tails. so yeah, they have groups :) oi: yes, you need a modeler to mirror an object. poser is not a modeler. now what are you guys doing? apply the flipped hair as a morph target to the original hair? hmmm. and the other morphs still work right? do the kozaburo 'right' and 'left' deals still go right and left, or do they go left and right now?
My hair has posable hair has groups, but they are all ghost groups, I figured it would be a lot easier to morph that way! Yep, just mirroed it and exported, used that as a morph target. I didn't use the normal Max fix for the inverted winding order when I tried it, though, which is why (I think) mine was inside-out (which doesn't effect renders). The morphs didn't work right when I tried them though, I think in and out and up and down would work O.K., but morphs that move to the side are now going the wrong way, and if they have an Z or X component you can't just turn the dial the other way. Anyway, we learned a new trick, we can include "mirror" morphs in stuff!
A great deal of the time, hair models that would otherwise suit my needs perfectly are wrong to me in one way: The part is on the wrong side. Recently, I've learned how to bring in an obj and mirror it. If the Hair was just an Hr2 then I'd be okay with just this. However, with a Cr2 type model, I realize that some of the information would need to be reassigned. I'm guessing that it would be a matter of making all notations that refer to the X axis the opposite negative or positive. Also, any Morph targets would have to be exported, mirrored, then loaded back into the new model. This is easy and not a problem at all. How do I rearrange the Cr2 and what exactly would have to be rearranged? Would it be way too time consuming? Any help appreciated. -WTB
