Sun, Jan 26, 11:02 PM CST
Subject: Open GL
arrow1 ( ) posted Fri, 28 March 2003 at 4:54 PM · edited Sun, 26 January 2025 at 10:50 PM
Can someone tell me what open GL is? I have a 768 megs of ram and a athlon 1.7 gig chip running on XP Professional with Poser Propack and Vue 4. Do I need to click it on or off. arrow1
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
MightyPete ( ) posted Fri, 28 March 2003 at 5:13 PM
OpenGL is a system of instructions to draw 3d objects. Like Quake III. It slows down Vue though. It bogs the program down actaully.It shouldn't but it does. It's up to you wherther to turn it off or on. If it works on and you like it then use it. Personally I have it turned off and only use it if I need it to make detailed meshes. Try turning it on. I think it's on by default anyway. If it works then use it if not then turn it off. You have to work in wire frame mode then but that is not to bad and the program works lots faster and you can create 10 X more complex things with it.
gebe ( ) posted Fri, 28 March 2003 at 5:33 PM
I use OpenGL:-)
If you only can see wireframe, you may have OpenGL disabled (see FILE--->OPTIONS).
Otherwise you can see your interface like this.
Guitta
arrow1 ( ) posted Fri, 28 March 2003 at 7:14 PM
Many Thanks for your replies.I have checked and open GL is ticked.I assume it is working ok! arrow1
Cheers ( ) posted Sat, 29 March 2003 at 3:10 AM
OpenGL is soley dependant on what graphics chip you have. If you have a nVIDIA or ATI base graphics card, then you probably do have OpenGL available to you. Some on board graphics chips, such as some SIS graphics chips have very limited (if any) OpenGL support...so for 3D graphics use with the majority of 3D applications their use is limited. Cheers
Twitter: Follow @the3dscene
arrow1 ( ) posted Sat, 29 March 2003 at 12:41 PM
I havs a GeForce4 MX420. arrow1
Dale B ( ) posted Sat, 29 March 2003 at 6:04 PM
Then be real careful about getting any new drivers. Nvidia slants driver performance for games, not graphics programs. A 'needed upgrade' could wind up forcing you to disable GL, or rolling the driver version back to the one where it worked.
jibrielson ( ) posted Sun, 30 March 2003 at 6:32 PM
Guita , i.ve tick open gl option but why my view still in wireframe
gebe ( ) posted Mon, 31 March 2003 at 1:30 AM
jibrielson, when OpenGL is switched on, you will see the above icon on top of each of the 4 windows. Clck on it and select SMOOTH SHADED from the list. Do this for all windows where you want to have OpenGL. Personally I use it in the main view and the top view and for the two other windows choose wireframe. You can color your objects as you used to do with wireframe to recognice it easily. Hope this helps? :-)Guitta [![guittalogo.GIF](http://www.guitta.net/icones/guittalogo.GIF)](http://www.guitta.net/)
