Fri, Jan 10, 12:46 AM CST
Subject: Correct Reference
Marque ( ) posted Tue, 01 April 2003 at 10:00 AM · edited Thu, 12 December 2024 at 9:02 AM
Can someone please do the steps for me to use this? I start it and it seems to be done but it never gives me the option the do the corrections?? Thanks, Marque
Marque ( ) posted Tue, 01 April 2003 at 10:19 AM
It appears to be finished and tells me to select a dir and do the corrections, but I'm not able to select the directory. Can someone help out please? Can't use my pboost until I do this. Marque
Marque ( ) posted Tue, 01 April 2003 at 10:20 AM
Hummm, think I figured it out. Marque Goes looking for lots of coffee......
Marque ( ) posted Tue, 01 April 2003 at 10:21 AM
Now it says I have an access violation of a memory 0000018D
Marque ( ) posted Tue, 01 April 2003 at 10:22 AM
and crashed. Guess I won't get to use pboost after all. Marque
c1rcle ( ) posted Tue, 01 April 2003 at 10:39 AM
which version of CR have you got? 1.2 is the most upto date as far as I know.
Marque ( ) posted Tue, 01 April 2003 at 11:04 AM
Getting those memory errors again. Running 1_2_1 Marque
Marque ( ) posted Tue, 01 April 2003 at 11:06 AM
Just ran it again and got a different mem error. Wonder why it won't work? Marque
c1rcle ( ) posted Tue, 01 April 2003 at 11:08 AM
very odd, I hae the same version but no problems at all, I just ran it to make sure myself.
Marque ( ) posted Tue, 01 April 2003 at 11:14 AM
Ok, pboost is working enough to get some things done, I will get this figured out, just impatient. Marque
SAMS3D ( ) posted Tue, 01 April 2003 at 12:02 PM
Marque are you talking to yourself again.....LOL...just kidding, so you got it....how do you like it? Think it is saving time? Sharen
Cyhiraeth ( ) posted Tue, 01 April 2003 at 12:10 PM
Marque, I was having the same problems! It said "Access violation at 0000F51C Read of address 0000F51C" I tried it 3 times and it did the same thing, so I just said the hell with it and went into the Deep File Editor in Pboost and I am making the references by hand. It will take longer, but at least I haven't gotten any error messages. If anyone knows what causes this or what to do about it, please post it! Thanks,
Marque ( ) posted Tue, 01 April 2003 at 12:42 PM
How do you do the references by hand? Thanks Cyhiraeth for letting me know I'm not crazy. 8^) Marque
Cyhiraeth ( ) posted Tue, 01 April 2003 at 1:41 PM
Well, I'm not so sure I am doing it right either. I bring up Pboost, go to Menu, go to Deep File Editor. You then have a window that looks a lot like the Materials editor in Poser. You then click in Pboost on the folder, then subfolder, then CR2 that you want to correct its reference; for instance, Default Characters:Koshini:Baby Doll Then, it will put one of three colored "links" to the texture that is supposed to go with it. If it is green, all is well. If it is blue, it is there, but it can't find it. If it is red, it can't find it at all. If blue, you click on the blue sentence, then click on "Correct" and then click OK. If it is red, click on the red statement, then click "Change" then you have to manually look for the file. I'm sure this is confusing the way I am explaining it. You can also go to Hogsoft's website and he explains it better.
Marque ( ) posted Tue, 01 April 2003 at 2:56 PM
Thank you! I appreciate you taking the time to write it all out for me. Marque
PeterWahoo ( ) posted Tue, 01 April 2003 at 9:24 PM
You're apparently confusing two entirely different programs: 1.) CorrectReference is a stand-alone freebie product 2.) Deep FIle Editor is part of PBooost... You're better off using CorrectReference. You can check much more than Deep File Editor.
Cyhiraeth ( ) posted Tue, 01 April 2003 at 9:49 PM
Well, that's what I tried doing, but Correct Reference keeps giving me weird error messages and I can't get it to work.
Marque ( ) posted Wed, 02 April 2003 at 8:14 AM
Same here getting memory errors with Correct Reference. Was using it so I could use Pboost. Marque
