Sun, Feb 2, 2:02 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: How Do I Rotate A Sphere 360 Degrees?
nemisis ( ) posted Thu, 25 May 2000 at 4:50 PM · edited Sun, 02 February 2025 at 1:53 PM
Hi, I am trying to create an animation of a planet rotating. I have checked all tools and all I can find in (modifiers, constraints, etc) is the ability to move a sphere 180 degrees. How do you get a complete revolution??
ClintH ( ) posted Thu, 25 May 2000 at 5:56 PM
Spin the planets Yaw 180 degrees... Maybe set the animation for 5 seconds at 15fps... Move the timeline marker to the 5 second point. Select the planet and open the Properties window. Move the Yaw parameter 180 degrees from its current location. This should add a ekyframe at 5 seconds in the timeline. If you press the run button the planet should now spin.. That help? If not let me know. Clint
Clint Hawkins
(Zakk Wylde (2007))
keithw ( ) posted Thu, 25 May 2000 at 6:06 PM
You can apply the spin modifier to an object to get it to spin.
nemisis ( ) posted Thu, 25 May 2000 at 6:31 PM
Hi Clint, No luck. Still can only rotate it 180 degrees. I tried the spin modifier, but it spins too fast, I think the lowest setting you can use is 1 rotation/sec. Any other ideas?? I tried setting 2 key frames( 1 halfway (4 sec) and one at the end (8 sec) but it just reverses the rotation at the 4 sec mark. Keithw, is there a way to sec the spin/sec to .25 rotations/sec??
keithw ( ) posted Thu, 25 May 2000 at 7:15 PM
Nemisis, I'm not sure what you mean? You can set the number of rotations per second. If you set the rotatations per second to .25 and the length of the animation to 4 seconds your planet will make one complete rotation during the 4 second animation. If the cycles per second are a positive number the planet will rotate clockwise. a negative number will rotate it counterclockwise Keith
nemisis ( ) posted Thu, 25 May 2000 at 7:17 PM
Hi Keith, Carrara will not allow me to set anything but a whole number. 1 is as low as I can go.
nemisis ( ) posted Thu, 25 May 2000 at 7:22 PM
Hi Keith & Clint, I tried to set the spin again to .25/sec and this time it worked fine, sorry guys. Thanks alot
hoborg ( ) posted Fri, 26 May 2000 at 1:06 PM
Also what you can do (for future reference) Is have the planet go 180 at the first keyframe and then at the middle keyframe set it to 0 then at the last set it to -180. That'll do it. Although Spin works too. :) Hoborg
