Wed, Feb 5, 5:28 PM CST
Subject: Using paths?
Czarinaqueen ( ) posted Tue, 08 April 2003 at 1:09 AM · edited Tue, 04 February 2025 at 9:42 AM
When you go in the create menu there ae some paths and when I try to put them on my picture nothing happens...what are they supposed to do? How do you use them?
Claymor ( ) posted Tue, 08 April 2003 at 1:17 AM
Paths are used in animation to allows for smoother movement. You can have a camera follow a path or conform an object to a path and have IT follow the path as you progress through your frames. They are not actual objects in that they don't render. The other use for paths in doing a multi-replicate of an object. If you conform the original object to the path the replications will follow the path in effect giving you a string of objects.
Czarinaqueen ( ) posted Tue, 08 April 2003 at 1:38 AM
String of objects that sounds cool...is it a easy as you point it out to be?
bikermouse ( ) posted Tue, 08 April 2003 at 2:39 AM
try this thread. Wait for it to completely download. There are several useful contributions here including 3 I did as picture / tips.
GROINGRINDER ( ) posted Tue, 08 April 2003 at 6:00 AM
Yes that was a great and informative thread.
Aldaron ( ) posted Tue, 08 April 2003 at 8:00 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=923144
Along this same thought the above link is a thread where I created a twisted tree using paths.
bikermouse ( ) posted Wed, 09 April 2003 at 1:00 AM
Aldaron, Ah I got it this time. When you posted this I hadn't yet gotten B5(metaballs) nor explored using paths in that way for myself. thanks for the link! - TJ
