Wed, Feb 5, 2:15 PM CST
Subject: Vue d'Sprit and Bryce
efitzger ( ) posted Tue, 08 April 2003 at 7:00 PM ยท edited Tue, 28 January 2025 at 9:39 AM
Attached Link: Bryce versus Vue d'Sprit
Hi, I have been a Bryce user since the first version whenever that was, and recently learned that Corel has no current plans to update this program. I really like what I have seen about Vue d'Sprit and was wondering if there are current or past users of Bryce that have switched to Vue or use both. I am interested in knowing general terms how they compare as far as ease of use, rendering time and if there is much of a learning curve going from Bryce to Vue d'Sprit. I just downloaded the demo version and hope to play with it to see how it compares. Thanks for any advice you may have. Ed Fitzgerald
MightyPete ( ) posted Tue, 08 April 2003 at 7:07 PM
Click on the FAQ link, I even added a link there to a Bryce forum where this topic had already had take place. Beyond a dought this is the most frequently asked question here.
efitzger ( ) posted Tue, 08 April 2003 at 7:16 PM
Thanks I will take a look. Ed
nish ( ) posted Wed, 09 April 2003 at 1:04 AM
I've used Bryce for a while, now trasferred to Vue. As far as render time goes, I think Vue is little faster then Bryce. But, I didn't really compared it in that perspective. As far as ease of use goes, Vue is way better then Bryce. Even in options wise. I've been using Vue Demo for quite a while, posted some images also. Recently baught the full version and I have to say I'm happy with it so far. However, Vue has a little stability problem.
efitzger ( ) posted Wed, 09 April 2003 at 2:20 AM
Thanks for your response. I am glad to hear you like it. By stabiliy problems I assume you mean that it crashes occasionally.
MightyPete ( ) posted Wed, 09 April 2003 at 3:24 AM
Well I think it has to do with the operating system more than on Vue. It does not crash on me and I do a lot of work with it. Lots of work, I push it to the limits. Make sure your running 4.12. You can't judge Vue too closly with the demo the program is much better. It just gives you a taste.
TheWingedOne ( ) posted Wed, 09 April 2003 at 7:08 AM
Used Bryce for some time before switching to Vue. If you plan to use Poser figures Vue is the program of your choice. And it's render engine is a little bit faster than Bryce's. Vue is quite eays to learn, since it's GUI it's much easier to understand, but that might be only me. ;) Phil
nish ( ) posted Wed, 09 April 2003 at 1:11 PM
Umm! It actually doesn't crashes, but it used to freeze up a lot in Demo. Even on the full version it freezed up several time on me. Since, I'm a new user, I'm taking MightyPete's words in consideration. Probably soon, I'll do a fresh installation of Windows, that should stop the freezing. However, the bottom line is I prefer Vue more then Bryce.
efitzger ( ) posted Wed, 09 April 2003 at 3:15 PM
Can I ask what version of windows you are using? I have winxp home edition and, it seems fairly stable
nish ( ) posted Wed, 09 April 2003 at 8:55 PM
I have XP pro edition with the service pack. It's fairly stable too; little slow may be cuz I have so many programs installed in it. Comparing with new technology my pc is little old ... P4, 1.4Ghz & 512 RD ram. I think freezing up has lot to do with runtime environments and plug-ins. Maybe I have one or two of those, which is not suitable with Vue. Afterall you know, there are no such thing as "100% perfect". :)
Tomsde ( ) posted Fri, 11 April 2003 at 11:38 AM
An aside here, if you plan on using Poser with Vue 4 you must use Poser 4 or Poser 4 Pro Pack. Vue Poser import filter doesn't work with P5 yet, but they are supposedly working on it.
