Forum Moderators: Staff
Hope this helps.
I wish that I COULD provide you with a basic set of instructions on how to install EVERYTHING in Poser 5. That would be wonderful.
Unfortunately, there is NOT a simple 1,2,3 answer to your question.
Frankly, Poser 5 tends to be unforgiving -- it is not a "plug 'n play" type of software. Poser 5 is very detailed, and the program requires detailed understanding to master.
It is like asking if there is a simple, easy way to master calculus. While this is not an entirely apt analogy (because Poser and calculus aren't really comparable); the analogy still applies, I think.
There is no ONE way to install every prop, figure, light set, etc.. Each item must be installed in a way that specifically addresses that individual item. Rarely will you find any two installations that are exactly alike.
Most freestuff items come with a "readme.txt" file included in the .zip. The "readme" file will usually provide instructions on how to install the prop/figure/whatever. The readme file is a helpful addition provided by freestuff creators.
Also, some freestuff items are provided as .exe files, which will self-install.
Keep these things in mind:
.pp2 files belong in the Runtimelibrariesprops folders
.cr2 files belong in the Runtimelibrariesfigures folders
.fc2 files belong in the Runtimelibrariesface folders
.obj files belong in the RuntimeGeometries folders
Once again, I hope that this helps. But, when it comes to Poser 5, "simple" isn't possible.
Thank you very much,xenophonz - yes, I didn't think it would be easy but didn't know it would be that hard either, lol. I did successfully install a couple of things yesterday, it was very exciting...sad I know but hey, it was an achievement, lol - thank you again. Replying from work but itching to get home and work in Poser (and Bryce) some more. :o)
Attached Link: http://www.morphography.uk.vu/fileguide_1.html
It's for Poser 4, but this tutorial should help you out a bit. :-)This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
HOW??! I've searched the net, read around, and STILL can't find any simple instructions on installing props, clothes...heck, anything!...into where they belong. I see such wonderful things in the free section, I have some downloaded and saved - have even ventured to try to figure it out myself but no go. So if anyone can tell me a straight 1,2,3 way to get these things into their correct folders after you unzip them, it would be very much appreciated. Btw, I'm using Poser 5...thank you again.
