Mon, Feb 24, 5:22 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2025 Feb 23 2:34 pm)
Subject: Probably 1000th time asked - installing poser props?
FirstBlueMoon ( ) posted Wed, 16 April 2003 at 5:06 PM · edited Sun, 09 February 2025 at 12:24 PM
HOW??! I've searched the net, read around, and STILL can't find any simple instructions on installing props, clothes...heck, anything!...into where they belong. I see such wonderful things in the free section, I have some downloaded and saved - have even ventured to try to figure it out myself but no go. So if anyone can tell me a straight 1,2,3 way to get these things into their correct folders after you unzip them, it would be very much appreciated. Btw, I'm using Poser 5...thank you again.
XENOPHONZ ( ) posted Wed, 16 April 2003 at 6:43 PM
Hope this helps.
I wish that I COULD provide you with a basic set of instructions on how to install EVERYTHING in Poser 5. That would be wonderful.
Unfortunately, there is NOT a simple 1,2,3 answer to your question.
Frankly, Poser 5 tends to be unforgiving -- it is not a "plug 'n play" type of software. Poser 5 is very detailed, and the program requires detailed understanding to master.
It is like asking if there is a simple, easy way to master calculus. While this is not an entirely apt analogy (because Poser and calculus aren't really comparable); the analogy still applies, I think.
There is no ONE way to install every prop, figure, light set, etc.. Each item must be installed in a way that specifically addresses that individual item. Rarely will you find any two installations that are exactly alike.
Most freestuff items come with a "readme.txt" file included in the .zip. The "readme" file will usually provide instructions on how to install the prop/figure/whatever. The readme file is a helpful addition provided by freestuff creators.
Also, some freestuff items are provided as .exe files, which will self-install.
Keep these things in mind:
.pp2 files belong in the Runtimelibrariesprops folders
.cr2 files belong in the Runtimelibrariesfigures folders
.fc2 files belong in the Runtimelibrariesface folders
.obj files belong in the RuntimeGeometries folders
Once again, I hope that this helps. But, when it comes to Poser 5, "simple" isn't possible.
Something To Do At 3:00AM
FirstBlueMoon ( ) posted Thu, 17 April 2003 at 12:29 PM
Thank you very much,xenophonz - yes, I didn't think it would be easy but didn't know it would be that hard either, lol. I did successfully install a couple of things yesterday, it was very exciting...sad I know but hey, it was an achievement, lol - thank you again. Replying from work but itching to get home and work in Poser (and Bryce) some more. :o)
EnglishBob ( ) posted Thu, 17 April 2003 at 5:17 PM
Attached Link: http://www.morphography.uk.vu/fileguide_1.html
It's for Poser 4, but this tutorial should help you out a bit. :-)
doozy ( ) posted Fri, 18 April 2003 at 1:39 PM
For Poser 4 on Mac, get the free app Macinstaller. It puts all files in their places for you.
