Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
Attached Link: Rc2000's 3D and Animation at Monsters4u
You may want to resave the original file as a new file, say maybe place a 2 after the file name. Use this new file to experiment with. That way you'll have the original to go back to. Select your head and jump into it. Have multiple views of the head. Looking at the side view of the head, click and drag the Marquee tool over vertices and polygons you want to move. Check your head-on view of the face and you'll see that the Marquee has also selected the same things on the other cheek. The Marque tool goes all the way thru the head when you use it. If you need to selct more, go back to the side view and press Shift as you select more vertices and polygons. Now, go to your head on view. Continue holding your Shift key and click on this view. If you release Shift and click on the window, you'll lose all the stuff you selected. Click on the Expand tool and release the Shift key. Drag left or right across the face. You'll see the parts you selected either go away from each other or go towards each other equally. If there are other parts of the cheek you want to widen or contract. deselect what you have and repeat using the Marquee tool and Shift if needed. You can select individual vertices, lines, or polygons like this and change both sides of the face. Just be sure to watch the head-on view of the face to make sure that the same things are selected on the other side of the head. Using this same thing, you can select sections on both sides and move them up, down, in, or out, depending on the view you're using. Use the side view for instance if you wanted to move the cheeks back more towards the face or out. Hope that helps. RcThanks for the Save Advice! I see the different views, but what is the selection tool? Is it the Marque, which is that? Could I have a screen shot...,please? Thanks for the SHift tip, is control subtract? Well where is the Expand Tool? I love being a Newbie, this is to fascinating! I wish this had fold up maps like RDS5, Bryce3, Poser 3, and Photoshop... >"You can select individual vertices, lines, or polygons like this and change both sides of the face." This is just what I wanted to hear... Using The Views...O that is how! Thanks... = )
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12417&Form.ShowMessage=1201730
I'm trying to do this in ZBrush right now also. I suspect Daz3D may be the modeler to keep handly, but these are also very nice, and here now! = )If you click and hold on the name of the view in the upper left corner of the view you will get a list of possible views, including any cameras that are in the scene. Just insert some and position and name them and you'll find them there. As for your screen-capture where you ask about the color of your object, the screen-shot shows the Modeling room, instead of the Shader room. Select your object in the Assembly room, then click on the paintbrush icon, second from the right. This will bring you into the Shader room, where you can adjust the color, transparency, reflectivity, etc for your object. Hope this helps! :>
The Marquee tool is selected by using the 'M' key. I would recommend doing one of the tutorials that is included with the program. In the Paint room, there are many options that don't seem to do much, until you know where to look, and describing that in detail here would be like me re-writing the maual. So, try out the tutorials, read the manual, and a lot of it will become more clear. Good luck, and have fun!
Also, how do I move around the elements of the UI. In Poser you just click on its title, but these have none.
