Sun, Jan 12, 6:33 PM CST
Subject: I just can't make a screenshot :(((
Doublecrash ( ) posted Thu, 01 May 2003 at 2:48 PM · edited Sun, 12 January 2025 at 6:30 PM
Hi all. This a stupid question, but I'm banging my head on the desk about this. I wanted to make a screenshot of the wireframe for a friend. I did it in the past, but today I just can't remember... no way. I printscreen, then load the image from the clipboard in my 2d editor and... all I get is one of the control palettes (the last one I clicked). Tried to click on the render window, nothing happens. Could someone help me to remember how I did it that one single time? :) And... what if I want to have a screenshot of the rendered/wireframe together? Just using the lil' box on the rightmost controls and then "export image" doesn't work... Thanx in advance. Stefano
Andini ( ) posted Thu, 01 May 2003 at 3:24 PM
I think as long as the program your catching the image from is open, you can use ALT-PrintScreen. I would load it into Photoshop or any other graphics program along with the rendered copy (a .bmp file in the same folder the Bryce file is saved). I'm not sure what the problem is.
Erlik ( ) posted Thu, 01 May 2003 at 3:57 PM
Simple printscreen should work. Try pressing PrtSc several times. BTW, Alt-PrtSc is for taking the screenshot of the active window, without the Windows' menu bar at the bottom. And apparently is very hard to get to work in Bryce.
-- erlik
Doublecrash ( ) posted Thu, 01 May 2003 at 4:25 PM
Thanx a lot! Erlik, you are right. You have to press only PrtSc, and not ALT-PrtSc as I was doing. Also thanx Andini for your interest! :)
AgentSmith ( ) posted Thu, 01 May 2003 at 5:44 PM
Make sure the blank window you are pasting into is the same exact size of your desktop resolution, meaning I keep mine at 1024x768, so when I paste a screenshot into Photoshop, my new document needs to be 1024x768. I only remember that little MS Paint program would ask if if I wanted to resize to fit the the paste, others don't. Maybe that will help. AS
Innovator ( ) posted Thu, 01 May 2003 at 6:56 PM
if you are using photoshop, when you hit printscreen, photoshop will automatically remember that resolution so when you click file new, it will have the rez saved so all you have to do is paste the image into the new window...hope that made some sense
TMGraphics ( ) posted Thu, 01 May 2003 at 7:06 PM
Attached Link: http://www.analogx.com
Go to this link and get the free little utility called "Capture". It is a real easy to use screen capture utility that will let you capture your desktop OR the active window at whatever resolution your monitor uses. Hope this helps! TMG
TMGraphics ( ) posted Thu, 01 May 2003 at 7:08 PM
Attached Link: http://www.analogx.com/contents/download/system.htm
Here is another link to it.... TMG
Doublecrash ( ) posted Thu, 01 May 2003 at 9:20 PM
Thanx a lot!
deadman67 ( ) posted Thu, 01 May 2003 at 11:24 PM
i use snagit6
jstuartj ( ) posted Thu, 01 May 2003 at 11:44 PM
Here is another nice screen grab utility, works great and has nice print capabilites. http://home.no.net/wingrab/ J. Stuart J.
Erlik ( ) posted Fri, 02 May 2003 at 2:38 AM
this is one area where PaintShopPro has a small advantage over Photoshop. In PSP, you just have to press Ctrl-V and the image automagically appears in a new file window. In Photoshop, it's as Innovator says.
-- erlik
pauljs75 ( ) posted Fri, 02 May 2003 at 8:57 AM
PSP also has a handy-dandy screen capture tool built in. You can even change the settings and all (ie: partial screen capture, etc.) I used it a lot when making my Wings3D tutorials. It should be right up there in the menu bar.
Barbequed Pixels?
