Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 18 2:45 pm)
Tony, It looks almost dead on. The texture is too dark though. Either pull it into Photoshop and adjust the hue and lightness (just a tad), or try making the ambient settings lighter. A little too much wrinkle on the forehead and under the eyes. It sort of makes him look like he's been sunburned instead of his usual pale sexy look. The upper lip is a little too long, but not by much. Although we are nitpicking a little. I'd recognize him from your work so far. Excellent job!
I think it's really looking great so far. Maybe try to shorten the space between the eyes and the mouth... ie shorten the nose and move everything upwards a bit. The bottom half of his face is to long. Maybe make the bottom lip a little thinner. I'd like to see him when you get done. I've always thought he was cute too. LOL
Quote from PDXJIMS: It sort of makes him look like he's been sunburned instead of his usual pale sexy look. I'm glad I not the only one who thinks that way LOL I am gonna start working on the texture map and bump/displacement. Chailynne; actually I have his eyes moved down about as far as I can, and his nose raised as far as I can. Mike mesh gets this real bad distortion that I cant seem to get rid of even at this hight, I have to post it out. I think it his nose ridge folding on itself. I'm just glad people think he is recognizable.
That's very, very good. You could try making the face a bit wider at the temples/cheekbones, would give you a little more space to move his eyes apart a tiny bit and make them a little bit bigger. It's difficult to say, what with the vastly different lighting, but it seems you might have the eye sockets a bit too deep.
I wouldn't try to go for the blown-out lighting in the source picture or we,um, I mean you will have probs lighting him. I've seen Macy look almost that dark in indoor scenes. All the comments were accurate-- Id concentrate on the nose rounder and some jowels if possible in the mesh-- I know the limititations of up and down on MIke. I knew him first thing before noticing the companion pict. Amazing job so far. Emily
Attached Link: http://www.3-AXIS.com
Not too much I can add based on the great input you've been getting. A couple of things I noticed: Looks like his eyes should be slightly larger. I also noticeed the shape of his nose. I looks like it should be wider at the nostrils and slightly wider at the bridge of the nose (just above the nostrils. You may want to make the end of his nose (nostrils and point) a little bit flatter. It looks like W.H. Macey may have been a boxer before an actor. :) Very nice stuff. It is really looking good. All the best, JoeAttached Link: http://www.3-AXIS.com
I guess there is a little bit more I can add as a suggestion. His ears need to be a little bit more pointy and moved outward on the top like an elf. Cheers, JoeThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
