Mon, Dec 23, 12:46 PM CST
Subject: Grecian Hair @ DAZ / V3 ?
fretshredder ( ) posted Thu, 08 May 2003 at 12:37 PM · edited Mon, 23 December 2024 at 9:27 AM
Attached Link: Grecian Hair @ DAZ
Does anyone know if the Grecian Hair that is over at DAZ will work with V3 properly, meaning will it conform? If not has anyone heard from the creators about it being updated? I attempted to email both the creators and have not heard back. If you're not sure what I am referring to check the linkage... Any info would be appreciated :-) /gz
Lisas_Botanicals ( ) posted Thu, 08 May 2003 at 12:41 PM
I'm rendering with it on V3 now. I know there are a few ways to get it to work -- one being not conforming it, but I conformed it and then used the trans and rotate dials on the "body" of the hair to get it into the right position, a bit of scale here and there and a bit of tweaking on the "head" portion and it works beautifully. I think you can also tweak it into position and then parent it to V3 and it will work. Either way, after tweaking it save it into the hair library and it's one click away from using next time. :) Lisa
SAMS3D ( ) posted Thu, 08 May 2003 at 1:22 PM
I use it with V3...Sharen
Porthos ( ) posted Thu, 08 May 2003 at 1:38 PM
I think Jim Burton had a V3 Hair fitter pose, which works on most hair!
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD 7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
FyreSpiryt ( ) posted Fri, 09 May 2003 at 7:32 AM
I applied Netherworks conforming pose, and had no problems afterwards. I've used it pretty often playing around.
LaurieA ( ) posted Fri, 09 May 2003 at 9:58 AM
Use Jim Burton's conforming hair pose for V3...snaps it right into place and it looks great :o). Laurie
fretshredder ( ) posted Fri, 09 May 2003 at 10:04 AM
Thanks everyone! I went ahead and picked up the hair...can somone point me to Jim Burton's hair pose? Thanks, /gz
caulbox ( ) posted Sat, 10 May 2003 at 6:09 PM
Can't help you with the Jim Burton pose unfortunately, but (sorry if I'm stating the obvious here) I find the easiest way to interchange V2/V3 hair figures is to simply set the hair figure parent to the character head, and then restore the hair figure. Works great with the Grecian hair and V3. Also works in reverse for "conforming" V3 hair figures like the bombshell to V2 characters.
LaurieA ( ) posted Sat, 10 May 2003 at 8:35 PM
Attached Link: http://www.poserpros.com/forums/viewtopic.php?t=7287
It's at PoserPro's. If you are a member, it's at the link. If you're not, register and it's in the freestuff club forum, 3 pages back. Laurie
fretshredder ( ) posted Sat, 10 May 2003 at 9:15 PM
yes I am a member over there as well... I will take a look at it. This hair is pretty darned sweet tho. Having fun playing with it, and love the curls.. thanks for the link Laurie :-) /gz
LaurieA ( ) posted Sat, 10 May 2003 at 9:23 PM
No problem :o). I love that hair too and it was nice to be able to use it on V3. Jim's pose does pretty well with it :o). Laurie
