Attached Link: http://antwrp.gsfc.nasa.gov/apod/image/0305/helix03_hst_big.jpg
Additive terrains. It's the only way unless you make a mesh then place additive materials on it. Hey you see this one? APOD? I'd say it's really cool. There is a link there on apod to a 260 meg file of that picture..Attached Link: http://www.renderosity.com/messages.ez?ForumID=107&Form.ShowMessage=1238761
Lost me ... I'm a Vue newbie (even though I've had it since last fall).Wow, that is a nice one ... nice res too. I personally like the Eagle nebula the best. Have you seen that one? It's amazing.
-Tim
PS> There's some pretty good action in the Bryce forum on this right now. Check out the link.
Attached Link: http://www.parkiesoft.com/Heli/Nebula.gif
Hi, interesting exercise to get a fully 3D model from a 2D picture in Vue.See this link for an animated GIF (2megs) of my results with the camera moving about 90deg across the face. It was created using a terrain with the image mapped to it and transparency added also. If this could work then let me know and I will put the Vue file on my site for you.
I am rendering a 360deg version moving the camera around the terrain. It has a couple of Hours to go so I will post a link tomorrow
Cheers
Neil
P.S. rendered in Final Mode
Wow, that looks almost spot on to what I need, that's great. I can see now how the use of terrains works quite well for this application. It looks like you used the Crab Nebula picture to map onto the terrain, right?
Yes, I definitely would love to get the Vue file! Just IM me the link if you want. No need to render the 360, I'm sold. ;) Are you using two different mapped terrains by any chance?
Thanks!
Best regards,
Tim
Attached Link: http://www.parkiesoft.com/Heli/Nebula.zip
Hi, I use a single terrain and the image mapped to it. Look for the humming bird tutorial to sort out the mapping. Basically it is as follows (Very brief) Make the image the same size as your terrain (1024*1024) make 1024*1024 terrain and reset default and then use the 'Picture' option set to 100% to import your picture exit terrain editor enter texture area and load the image (Rotating 180) Set offset to half the image size set the transparency to say around 80% and use the image set to negative (Rotated). (or use the negative image in zip file) map texture to object not world exit texture editor and then set the texture scale to 5.68 The numbers are explained in the humming bird tutorial. I think it is most likely referenced in this Groups FAQ Have fun Neil P.S. File size 2.5 megAttached Link: http://www.petes-oasis.com/hummingbird.html
Here is the link to that tutorial I used Cheers NeilThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
