Wed, Nov 27, 9:44 AM CST
Subject: Help me plz !
Gothic-Ice ( ) posted Fri, 16 May 2003 at 1:09 PM ยท edited Wed, 27 November 2024 at 9:41 AM
I need some help on poser 4 please. I need to change the eye's because the poser 4 eye's are these real dead fishy one's :P I try'ed to use some textures i found but i cant get em to work. I go to Matarials and the say edit eyeball and take wite as the colour and all but it wont work ! The other textures i try on other stuff alwasy works i just cant get the eye's to work. Plz help me out ~Gothic
SAMS3D ( ) posted Fri, 16 May 2003 at 2:17 PM
First of all, you have to actually click on the eye ball, not the figure. Each eyeball has it's own body (so to speak), so if you make sure you have selected the eyeball itself, then go to your materials editor...you should get it to work. Sharen Or maybe you want to click on the figure then go to the texture map from their. Up to you. Sharen
maclean ( ) posted Fri, 16 May 2003 at 2:25 PM
If you search freestuff, you should find some eye props. There used to be one called 'Real Eyes' I think. mac
Patricia ( ) posted Fri, 16 May 2003 at 3:40 PM
Are you sure the textures you're using are for P4 eyes? They might be for Real Eyes by Cake1 or RDNA Eyez or the new Blackeyes by Blackhearted. If they are, they won't show up, because these sets install a new prop eyeball in place of the P4 one.
Gothic-Ice ( ) posted Fri, 16 May 2003 at 3:58 PM
No they are just normal Bmp's i made and sized them to fit. No prop's or anything. Tanks for the help tough i'll try it :D
Gothic-Ice ( ) posted Fri, 16 May 2003 at 4:15 PM
Ok im still not getting this right :( And i really need it ! :'( I clicked on the eyeball and still it didnt work. I tried converting the BMP file to a TIF still nothing :/ Still open to any help. Might try to get the eye prop thing. Sorry to bother you all again.
Crescent ( ) posted Fri, 16 May 2003 at 5:03 PM
Each figure has it's own texture coordinates. Are you putting your new eyeball textures in the correct places? You can not simply create an eyeball texture and have it work unless it's in the proper spot in the file. You can take the texture template for your figure and texture just the eyeball area, leaving the rest of it blank, or you can put your new eyeball textures on a currently existing texture. Hope this makes sense! Cres
lupus ( ) posted Fri, 16 May 2003 at 5:06 PM
What kind of model are you using? P3, P4, V1-2-3.... ? if it's Victoria then you will have to make the Eyeballs transparent....
Gothic-Ice ( ) posted Fri, 16 May 2003 at 5:17 PM
Nah im am usin P4. Its ok i figuerd out an "easyer" way do do it :) I just use Adobe Photoshop 6.0 and make some layers. Thanks to a toturail i read. It looks pretty good :) Thanks for the help though but i think i'll have to reinstall my poser :) Thanks again ~Gothic
lesbentley ( ) posted Sat, 17 May 2003 at 10:12 AM
To put some sparkle in Posettes eyes you can use a sphere made by exporting one of posettes eyeballs as an object. Set it to transparent, parent one to each eye, and save eah to a pallet as a smart prop. The props will reflect the actual lighting in the document, giving natural highlights Image above shows one eye prop set to transparent, the other coloured orange and the transparency removed, so you can see what it looks like.
