Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 9:06 pm)
I opened up poser and tried there basic props and it looks like they all have the origin at the ends of one side. so you probly need to center them some more. Use wire frame display mode and double click the prop and check the show origin box. This opens up 3 new dials to use . The origin Y dial should move it to the center of the clyndar . I would leave the 2 cones origin alone. When it centered move the cones in and parent them then drop it to the floor save it and export / import it back into poser .
All I really want is a cylinder with a cone on each end. After an hour I finally got the 3pieces to stick/become one. Great but it would only let me move it on the X & Y axis forget Z, no go. Then for the heck of it I went to the Materials editor and assigned materials, then saved to props library and deleted the new prop and tried to load it. It loaded but was invisible. All I want is a NoseSpike type piercing I can put a texture on and scale and move as I need. I was following Geeps tute but it got confusing because what he was doing was more complex. Any insights oh great and knowledgeable ones ??????
