No Poser gurus available at the moment, so I'll try - you might find these links useful : http://www.renderosity.com/messages.ez?Form.ShowMessage=347959 http://www.renderosity.com/messages.ez?Form.ShowMessage=348598 - and if you buy PhilC's CD, you'll get all the guru advice you need (and no, I don't work for him ;o) )
What is it that make the clothes conform, the basic that makes it look similar to a conform? Should all the center points align, and then you tweek the others?
I have done PhilC's and some of yours, thip, but nothing comes right. With altering a cr2 file, something really weird happens. But I have gone over and made PHI file, and it at least looks like the same thing almost when I try to pose. I have done this before, but never managed to make it conform.
Attached Link: http://www.dietcontroller.info/no/Gown.zip
If it is better and you want to look at the files, they are at attached linkI have tried to tweak the center points, hours and hours are just flying and I getting nowhere. Or as a clever man said:" I have learned what does not work."
"Disappearing" models are very often caused by an incorrect figureres line. In my case, the figureres lines (always make sure to correct both of them) were : figureResFile :Runtime:Geometries:Gown:P4mangown2.obj (...P4mangown2 being the newly-saved gown OBJ). Also be sure to check that you've saved your model with the "Include existing groups" option on. Otherwise, Poser will find the model, but not the groups needed for the body parts, and simply not use any part of the model = you'll see nothing of it. To check for this, open the model in UVmapper and try a select-by-group - if there are no groups to choose, there are no groups in the OBJ.
I have followed an apparantly good tut for making clothes and conforming, but I still don't get it?! (Poser 4)
I have made a simple gown for both P4 man and woman just to see if I could make it. I have used the male/female overcoat.cr2 file for reference, which I believe is sufficient parameters for both gowns. I followed the tut to the end where I conformed, and then... zjoing! It looked like it exploded.
My gown, I see, has the same parameters now as the overcoat. But I see this, that when I load the gown it is placed higher than the overcoat. I believe that this has something to do with the scale of the obj file. After model I put it in UV mapper Pro and slice it, export it to import it in Carrara. Here I scale and fit the gown on a native Poser obj. After exporting it from here, it has the right size, but as I said it don't import to the right place in Poser. And I get distorted clothes.
I tried once before to make it around with PHI builder, with no luck. That was two years ago. I just abondoned the whole thing, but it is very anoying that I can not make this.
Please, some Poser guru, share your cleverness?
I have Amapi, Poser 4, Carrara, Strata, Bryce and UVMPro.
