Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
how large in mb's is the .obj its reading? I've gotten that error as well..
Handle every stressful situation like a dog.
If you can't eat it or play with it,
just pee on it and walk away. :-)
I wouldnt have to manage my anger
if people would manage their stupidity......
Â
Make sure your object is in the Poser geometries folder that you want, also make sure your phi builder application is in the Poser.exe folder. Then open the phi builder application, and click object, your geometries folder will open and find your object. You should be good to go from there. Sharen Check the names for your groups, they may be to long.
Grid, Here are a few things you can do to improve movements in a model. First, open the cr2 file in notepad and look in the body part you're modifying under 'channels'. For the parts you want to slide, change the value for all 3 trans dials (X, Y and Z) from 'hidden 1' to 'hidden 0'. Resave the file as a cr2. When you open it in poser, you will see the 3 trans dials. What you can do now is this. Say you only want the chamber to move up to a certain point and then stop. Find out which trans dial moves it, figure out the value you want, then double-click on the parameter dial, and in the box that opens, set minimum and maximum values. If it moves 0.100, then 0 (zero) would be the minimum and 0.100 would be the max. If it was -0.100, then that would be the minimum and 0 the max. (Minimum is always less than maximum). Once you figure it out, resave the gun to the library, open the cr2 in notepad again, and for that trans channel, set 'force limits 0' to force limits 4'. Save it and open the gun in poser. The chamber will now stop automatically at the value you've chosen. If you decide to change the value, you can do it in the dialog box and the 'forced limits' will still work. This allows you to move the chamber without it shooting off and disappearing inside the gun. For any dials you don't want to accidentally rotate, do the same thing. Set force limits to zero for those dials in the cr2, then in the dialog box, set BOTH minimum and maximum limits to 0 (zero). Now they won't rotate at all, unless you decide to change the limits later. mac
PS You may want to resave the cr2 under a new name if you're not used to poser hacking. Just in case. I don't know how much you know about it, so if anything's not clear, just yell. Also, if you're interested, the reason the trans dials are hidden is because that body part is a child, ie. parented to another body part. Poser always hides the trans dials for parented parts. If you had made the PHI file as it is in post #8 (with all body parts numbered '1'), poser would have shown the trans dials for all body parts. But then you would have had to do the parenting in the cr2. I always leave trans dials unhidden, and if I have a model with a large number of body parts, I don't parent anything. That saves me unhiding everything. Then I do the parenting in the cr2, but it can be a pain if you're not used to it. mac PPS Sharen. Sorry to hijack the thread. You were doing fine.
I get this error First i model, Then open in uv maper Save it.. Then try to open with PhiBuilder Application I get this error (Text eceeds memo capasity) Whats going on here? I have looked on the internet for the help files and Did some research but nothign came up
