Sat, Feb 15, 3:48 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: HELP, too many objects in my Poser4 scene?
Tintifax ( ) posted Mon, 16 June 2003 at 3:09 PM ยท edited Fri, 07 February 2025 at 1:52 AM
I just built a scenery that consists of about 94 props. Everything seemed OK, when I saved this scene as *.pz3. When I loaded it again, the props where all here, but some of the props just forgot the transistion and rotation they should have and thus were located at the default place. Is this a known issue? What can i do against it? I'm using the german version of Poser 4.0.3. - Walter
geoegress ( ) posted Mon, 16 June 2003 at 6:27 PM
weird- I haven't had that problem or seen it posted here before- bookmark
3dgRobi ( ) posted Mon, 16 June 2003 at 7:45 PM
94 props ist ne menge, Walter. Hast du welche davon Gruppiert? ;] - Ernst
lesbentley ( ) posted Tue, 17 June 2003 at 8:35 AM
Try Edit>Memorize>All, (ALT+CTRL+A). It might help, I'm not sure.
Tintifax ( ) posted Tue, 17 June 2003 at 10:25 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=424332&Start=1&Sectionid=1&filter_genre_id=23&WhatsN
I restarted from scratch and this time it worked. All 94 props in. You can see part of this scenery in the Poser/Architecture Gallery. It seems that I found a Poser4 bug. I looked through the *.pz3 file and found the translation coordinates of some object were zero. So this happened during saving the file. After restarting Poser this bug was gone. Weird? Well everythings fine now. I just save and reload a complex scene step by step in case the bug returns. Thanks for your help - Walter PS.: Ich habe keine gruppiert. Die Menge kommt einfach daher das diese Halle aus vielen Teilen (Boden, Wandstke, Slen, etc.) besteht und damit beliebig neu kreiert werden kann.
3dgRobi ( ) posted Tue, 17 June 2003 at 12:50 PM
hehe wollte einfach nur was deutsches schreiben ;] freut mich, dass du das problem behoben hast. die halle ist fett ;] - ernst
