Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 10 4:55 pm)
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=424332&Start=1&Sectionid=1&filter_genre_id=23&WhatsN
I restarted from scratch and this time it worked. All 94 props in. You can see part of this scenery in the Poser/Architecture Gallery. It seems that I found a Poser4 bug. I looked through the *.pz3 file and found the translation coordinates of some object were zero. So this happened during saving the file. After restarting Poser this bug was gone. Weird? Well everythings fine now. I just save and reload a complex scene step by step in case the bug returns. Thanks for your help - Walter PS.: Ich habe keine gruppiert. Die Menge kommt einfach daher das diese Halle aus vielen Teilen (Boden, Wandstke, Slen, etc.) besteht und damit beliebig neu kreiert werden kann.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I just built a scenery that consists of about 94 props. Everything seemed OK, when I saved this scene as *.pz3. When I loaded it again, the props where all here, but some of the props just forgot the transistion and rotation they should have and thus were located at the default place. Is this a known issue? What can i do against it? I'm using the german version of Poser 4.0.3. - Walter
