Thu, Jan 30, 8:34 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
Subject: Lighting Problem with UltimateFIRE by romanceworks
dialyn ( ) posted Sun, 22 June 2003 at 1:58 PM · edited Wed, 29 January 2025 at 2:15 PM
I was playing with the freebie (so I shouldn't complain) but I can't figure out why I have more light underneath the table than above it. This is how it rendered.
dialyn ( ) posted Sun, 22 June 2003 at 1:59 PM
This is how the light sets up before rendering.
dialyn ( ) posted Sun, 22 June 2003 at 2:00 PM
I don't think there should be a pool of light beneath the table. Any ideas???? I could render without the light...but the idea is to use the UltimateFIRE as the only light source so, if I do that, it throws the graphic into complete darkness. Not what I want.
dialyn ( ) posted Sun, 22 June 2003 at 2:03 PM
BTW, if I look at the light from above, it looks centered over the table, so it isn't that it is in front of the table.
TrekkieGrrrl ( ) posted Sun, 22 June 2003 at 2:07 PM
Sounds to me like it's the question of shadow maps. If they're too small, light will leak thru gaps, in this case probably between the table and the wall.
Charlie_Tuna ( ) posted Sun, 22 June 2003 at 2:10 PM
Have you tried looking at it from the side? That way you could tell if the light's over the table or out front of it.
Why shouldn't speech be free? Very little of it is worth anything.
dialyn ( ) posted Sun, 22 June 2003 at 2:16 PM
Yeah, I looked at it from the side. It's over the table. It's almost as if the table has a whole in the center but it's not transparent in the top. I'll try the shadow maps. Thanks!!!
genny ( ) posted Sun, 22 June 2003 at 2:21 PM
Hi Dialyn, You can move the lights around with the dials. Just click onto one of them, say the ones that are pointing to the ground and rotate it and see if that helps. Genny
RHaseltine ( ) posted Sun, 22 June 2003 at 2:23 PM
Is there anything intersecting with the table - sometimes you get a bright spot on the forehead with hair/hats and it turns out that the head mesh is passing through the hair or hat mesh, using a magnet to suck the head in a bit clears the light (I suppose that could still be the shadow map, but the edge of the headcovering is still close to the surface of the head).
CDI ( ) posted Sun, 22 June 2003 at 2:23 PM
I think youre gonna need to adjust the Distant Start and End of the spotlight "Firelight 1" I set up a similar scene when I read this post and had to set the DS to 2 and DE to 3 before I got rid of the light on the floor but kept a decent shine on the table.
dialyn ( ) posted Sun, 22 June 2003 at 2:24 PM
You all are just too good. I'm heading back to the graphic and twitching dials. Thanks!!!
CDI ( ) posted Sun, 22 June 2003 at 2:26 PM
All I know about lighting I owe to Dr. Geep. LOL
dialyn ( ) posted Sun, 22 June 2003 at 2:39 PM
A lot of us owe what we know to Dr. Geep. I wish he'd come back. Anyway, you solved the problem!! Well done, everyone. I can happily put this question to rest now. :)
