Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 1:04 pm)
The downloaded characters are based on the Victoria1/2 mesh, and so pretty much require that mesh in order to work. The readme for the character/s should indicate which is required. While you MIGHT get away with using the victoria1 model (cheapest) it is unclear to me when and how this error is occurring, so it could well be that your character/s require some feature or features of the later, more expensive Victoria2. Buying Victoria2 is the solution. Cheers, Cliff Bowman
blMilWom.obj is the geometry file for victoria 1 and 2 so the only "fix" would be to get and install one of those two (Vic 1 is the cheaper of the two, so if the only reason you want it is to make that morph work then go for V1)
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
btw, she was under the 'Special Interest' option ot 'The Loft' as it was called.. If you searched for Victoria she probably wouldn't come up, as she's called Millennium Woman... ;) Hope that helped
I have downloaded a few characters which require the use of blMilWom.obj, which does not exist on my machine (I have verified this via a search on the hard disk). I have purchased Victoria3, which includes an obj file for Vic3 To Vic2, I thought this would be sufficient, but seemingly not. What is the solution to this problem ? Thanks in advance. regards, Andrew
