Sat, Feb 8, 10:17 PM CST
Subject: making a morphable prop
brandonc ( ) posted Fri, 27 June 2003 at 6:42 PM ยท edited Sat, 08 February 2025 at 9:40 PM
ok so i did this tut http://www.3dtoday.com/Tutorials/2001/Sept/Pmorphsinc/default.asp but i did a box then i used the points to make part of the box come out but what i want to do is make a morph for a "bulge" comming out of the wall but if i use 2 objects it doesnt work anyone know why?? thanks
compiler ( ) posted Sat, 28 June 2003 at 4:16 PM
What you have to do is 1-import the "flat wall.obj" 2-menu > object > load morph target 3-in the "find file" box, choose the "bulged wall.obj" 4-give a name to your morph (eg : "bulge") 5-in the parameter palette, turn the "bulge" dial from 0 to 1. The bulge should appear. If it doesn't work, please tell us where and how it failed so that you can give advice. Hope this helps. Compiler
lesbentley ( ) posted Sat, 28 June 2003 at 9:38 PM
I havent read the tutorial, but one way to make a bulging wall is to use a magnet on a Poser box prop.
