Sounds like you are applying the texture to the wrong Vicky. Blue geisha by Ecstasy is for V3, are you applying it to her and not accidently to V2 or the V3 to V2 model?
3-D Arena | Instagram | Facebook
I do not feel obliged to believe that the same
God who has endowed us with sense, reason, and intellect has
intended us to forgo their use.
-Galileo
Obviusly, you're applying a texture to a model it was not meant for. The MAT seems to work for the parts (eyes blue, etc...) but doesn't apply the texture right. You should triple check that it's the texture meant for V3 that you're using, and that it has not tampered with. Then try to apply the texture by hand to see if it works any better.
I'm new to poser so this might be a very simple question, I hope someone will have a good laugh and also the answer.
Sometime ago I downloaded the Ecstacy FS Blue Geisha MAT for V3 but I can't get the face right. I've tried eveything I know (not really much) but the face stays where it is, on the left cheek. The bodytexture seems OK but what on earth do I have to do to get the face in place?
