DITTO!!! What is needed is:- (1) A way to make any camera temporarily behave like the Dolly camera. (2) A way to make any camera orbit around any specified part or prop of any specified character and not change this when the user selects another character. If I am looking at Peter, the Posing camera orbits Peter; it is rather tedious when I select Peter's scuba set or flamethrower or etc and I then find that the Posing camera is now orbiting Richard.
I hadn't tried this yet, but you might be able to use something like the Aux camera... select it, then use the 'Point at' menu to fix it to one character or another.
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
Hey Mag :) I have the same prob and your message just got me to thinking so I tried something that works with this. 1) Put a prop type prop in the scene. I used a sphere. 2) Position it where you want the camera to turn around. 3) position the Camera right up close to the prop so it take up nearly all the screen. 4) Select the camera from the drop down menu at the bottom of the viewing area. 5) Then Object menu/point at and select the sphere. When I tried just zooming around the the camera virtualy just stayed in the same place and rotated. None of that moving outside walls etc. Hope this helps :)
Bwaaah?! What is my fault?! I ain't done nuttin... =/= ~TrekkieGrrrl
Heh, so I reckoned ;o) Actually I had forgot all about that fish bone. But with all those beach props popping up lately it may get a second life. I am SURE it will look great as a z-toon ;o)
I have always have problems with cameras in cramped spaces, a normal scaled living room or kitchen is cramped by this standard. To me it look like, the default camera is floating 5 meter away from there it point at. This makes setting up a scene very hard. You always end up outside the wall, it not always possible to remove the outer wall and you often have problems with other objects. Is it possible to make the camera closer to the target without have to make close up pictures or get the fish eye view? I would also like a camera that rotate around itself not around there it points. That would be very useful for indoor navigation, you could move around as in a 3D game with clipping disabled. Does anybody have any tips? Is there any tutorials about cameras? Magne
