Fri, Jan 10, 8:40 AM CST
Subject: Have You Seen A Clown Collar???? Etc.......
Strixowl ( ) posted Thu, 10 July 2003 at 8:14 PM · edited Fri, 29 November 2024 at 7:59 PM
The pleated or rufflee large round type. I'm also looking for anything Clown.....props etc. For Vic3 or adaptable to her. Already have FrankenClown. Thanks All, Strixowl
TalleyJC ( ) posted Thu, 10 July 2003 at 9:26 PM
If you post a Pic, I may be able to model one for you in Lightwave and export a .obj...
Strixowl ( ) posted Thu, 10 July 2003 at 9:32 PM
Cool. I'll see what I can find :-)
cooler ( ) posted Thu, 10 July 2003 at 9:59 PM
Strixowl, I have one for V2 as part of my jester (jesterette?) outfit in freestuff at 3D Commune
TalleyJC ( ) posted Thu, 10 July 2003 at 10:43 PM
Hey Strixowl....
This was real fast but like this?
xoconostle ( ) posted Fri, 11 July 2003 at 12:34 AM
Attached Link: http://www.creepyclown.com/creepydownloads.htm
You can easily isolate the collar.
RawArt ( ) posted Fri, 11 July 2003 at 6:19 AM
I have one of those collars I downloaded, but for the life of me I cannot fine the readme for it. It is in a folder called "LM Props"...perhaps someone can shed more light on this
Strixowl ( ) posted Fri, 11 July 2003 at 10:14 AM
Wow!! Thanks for all the help from everybody. TalleyJC-that was quick and looks really good.
TalleyJC ( ) posted Fri, 11 July 2003 at 12:34 PM
Do you want me to continue on it? Do you want it to fit Michael or Victoria? More wrinkles? smaller? larger? Should it stick out or drape on the shoulders?
Strixowl ( ) posted Fri, 11 July 2003 at 7:37 PM
TalleyJC-Sure if it's not any problem. It's for Victoria3. As for wrinkles it looks great as is and it should stick out. NOT drape. End result I'm after will be 3 of these layered with the ~~~~~~~~~~~ wrinkles of each layer lineing up with the layer above and/or below to make a 3layered collar.
TalleyJC ( ) posted Sat, 12 July 2003 at 12:12 AM
You may need to play with the UV map.... The UV I created in Lightwave didn't export so I did a quick Y axis, planar map in UVMapper.... I also have a silly texture I did for it as well as the Lightwacve UV map template that you should be able to use..... Give me an address I can email the zip file.... its 1.1meg.... don't worry the model is only 62k.... I added the texture maps to the zip
TalleyJC ( ) posted Sat, 12 July 2003 at 12:16 AM
Its still rough but I an tweak it as you need.
