Thu, Feb 20, 1:43 PM CST
Forum Moderators: RedPhantom
Subject: Another lighting question!
SothArtist ( ) posted Sun, 13 July 2003 at 2:13 AM · edited Tue, 18 February 2025 at 5:15 PM
I made 6 spotlights around a cube and saved the lights. But the lights don't even register, when rendering, that they have 'Cast shadows' on. They all have cast shadows turn on but when i render the scene it just goes straight into a render. This may have something to do with the prob I had earlier of the distance settings not going passed 1 (which Nance kindly helped me out with) Any ideas? :) Thanks all!
SothArtist ( ) posted Sun, 13 July 2003 at 7:27 AM
Welp.. I don't know. I have reinstalled poser and pro pack 3 times and its still the same. I am really beginning to think poser is simply not worth the dollars. I can't wait for Daz Studio :)
Jackson ( ) posted Sun, 13 July 2003 at 8:15 AM
Do you have "cast shadows" turned on in your render options? Hit ctrl-y and look under "surface detail." That's for p4, BTW.
SothArtist ( ) posted Sun, 13 July 2003 at 12:42 PM
Hey Jackson :) Yes. I have cast shadows on in render options and on each individual light. If i create new lights it works fine. Its only when I save the lights to a lights folder and then load them into a scene that it stops working. Hopefully will find what the prob is though :)
Nance ( ) posted Sun, 13 July 2003 at 9:08 PM
Make sure the lights' ShadowCams are still associated. (should have the same number of shadowcams, with similar names, as lights) Sometimes saving & reloading a parented light set causes the ShadowCams to get deleted. No shadowcams - no shadows.
SothArtist ( ) posted Sun, 13 July 2003 at 9:35 PM
Struck the nail right on the head again Nance :) No shadow cams. It must be the saving because any time I save a set of lights and reload them the shadow cam is gone. Even if they are not parented. I have downloaded the latest Service release and propack.. I just don't know.
Nance ( ) posted Sun, 13 July 2003 at 10:54 PM
Hmmm.... Well that's just not typical. Are you saying that if you: -create a group of NEW lights, (with shadowcams), -then save that set to the library, unparented -when you recall the set, the shadowcams are simply gone? I'm wondering if you have confirmed that lights you are working with actually had shadowcams before the save?
SothArtist ( ) posted Sun, 13 July 2003 at 11:15 PM
Attached Link: www.nailbiterdesigngroup.com/poser/lights/BTTestLights.lt2
Hey again Nance :) Thats exactly what i am saying :) Yes I have confirmed that. If I create a new light set and and render it before i save it, the shadow cams are there. If I then reload the lights into a scene the shadow cams are just gone. Heres a copy of a test light I made if you or anyone else are interested hehe I really do apreciate the time you have taken with me too! Wonderful :)
SothArtist ( ) posted Sun, 13 July 2003 at 11:31 PM
oh no.. New developement. It is when I use the subset button to select the lights that it does not save the shadow cams. If I dont use the subset button at all.. it saves the lights and their shadow cams. Please tell me using the subset button is right else I am going to feel like a complete and utter Punce!
Nance ( ) posted Mon, 14 July 2003 at 1:04 AM
Of course, the Subset button is for... uh... well... uhm ....seems I never actually tried that sucker myself. [Nance smacks himself on the forehead for a bad case of button blindness and wanders off mumbling, wondering what else he's missed]
Nance ( ) posted Mon, 14 July 2003 at 1:40 AM
Same results here using Subset.
Went a little farther trying to see if using identical internal names would cause the saved set to reclaim the shadowcams of existing lights. Ended up with a monster of mismatched light types and names that appeared to have reclaimed shadowcams but still would not cast shadows.
My head hurts.
SothArtist ( ) posted Mon, 14 July 2003 at 5:22 AM
lol Nance. Well it says in the manual to use the subset button but doesn't say anything about the shadow cams. Still now I know just to not use the subset button hehe. Again Thanks for everything! Hopefully one day I will be able to help you hehe. Have been making a lot of use of your shadow cam suggestion in regards to make shadows closer to the base of things :)
