Tue, Nov 19, 7:58 AM CST
Subject: Natural Hair - Problems in Poser 5
3Dream ( ) posted Mon, 14 July 2003 at 9:52 AM · edited Fri, 15 November 2024 at 9:09 PM
Attached Link: www.3Dream.org
Hello, I am the creator of Natural Hair. I built the 3d object in Rhino, the UV Map in IV Map pro, the textures in Adobe Photoshop and I use Poser Pro Pack. Recently I recived a email of Wenke telling me this:"I must show you something, I have Poser 5 and in the image i send you, you can see thats the light will change the colour of the top hair. So I don't know why but it happens for me." - see the picture The question is: Can someone tell me why this hair style dont work in Poser 5?
Just one more thing, my web site (www.3Dream.org) is currently with a lot of traffic so if you dont have this hair already, try to upload latter. Thank you. 3Dream.
STOREhttps://www.renderosity.com/marketplace/vendors/3Dream
FREEBIEShttps://www.renderosity.com/users/3Dream/freestuff
dialyn ( ) posted Mon, 14 July 2003 at 9:55 AM
Attached Link: http://www.horae.dti.ne.jp/%7Ekozaburo/dload/P5notice.html
Did they use displacement with the hair? The same thing happens with the hair from Digital Babes, among others, but displacement seems to solve the problem.
dialyn ( ) posted Mon, 14 July 2003 at 10:09 AM
Never mind...that's not the problem. I just tried rendering in Poser 5 and that didn't help.
stewer ( ) posted Mon, 14 July 2003 at 10:33 AM
Is Natural Hair a free item? I'd love to try figuring out what's going wrong here, but I can't download it. If it's free, I'd be happy if someone mirrored the file.
wenke ( ) posted Mon, 14 July 2003 at 10:56 AM
I've rendered this pic with a white global light. Same result with the Poser 4 Renderer. I've tried different render settings, but no luck. :o(
thgeisel ( ) posted Mon, 14 July 2003 at 11:25 AM
it is the way poser 5 treats normals. if you look at the mesh its done like folded and p5 treats them as if they were inside and dont take light. Think one cant correct it in poser itsself.
GraphicFoxx ( ) posted Mon, 14 July 2003 at 11:26 AM
Here's a test with a white global light...
GraphicFoxx ( ) posted Mon, 14 July 2003 at 11:28 AM
And one with a colored light... I don't seem to be getting that problem. I also tried just the standard lights, and they seemed ok. Picked up some of the color from the lower right light, but that's normal. Nothing like what wenke got.
stewer ( ) posted Mon, 14 July 2003 at 11:31 AM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1331059
Are these single-sided polygons? If so, it's probably a problem we solved recently: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1331059
Mazak ( ) posted Mon, 14 July 2003 at 11:41 AM
Use the production firefly mode; activate Use texture filtering. ? Mazak
Google+ Bodo Nittel
wenke ( ) posted Mon, 14 July 2003 at 12:18 PM
I use the production firefly with and without texture filtering, with displacement connect to texture/to transparence, all the same. Perhaps it is a SR-Problem? I have SR 3 installed.
stewer ( ) posted Mon, 14 July 2003 at 12:32 PM
Did you try the material node fix posted in the thread I linked to?
wenke ( ) posted Mon, 14 July 2003 at 12:56 PM
O.k. Here is the result of setting the diffuse node value: 1
wenke ( ) posted Mon, 14 July 2003 at 12:58 PM
Setting: 0.3 Here the texture looks bleached.
stewer ( ) posted Mon, 14 July 2003 at 1:07 PM
you should plug the texture into the new diffuse color node and set the diffuse_value in the PoserSurface node to 0.
stewer ( ) posted Mon, 14 July 2003 at 1:09 PM
Unplug the texture from the unused node channel.
stewer ( ) posted Mon, 14 July 2003 at 1:11 PM
The new diffuse node is a replacement for the top two channels of the PoserSurface node. It works exactly the same, except that it appears not have the problem with the one-sided polygon normals.
wenke ( ) posted Mon, 14 July 2003 at 1:27 PM
Thanks a lot stewer, it works ;o) Now I can make textures for the hair. So, my monthly download limit is reached, perhaps I can found somebody which is so nice to host them?
stewer ( ) posted Mon, 14 July 2003 at 2:41 PM
No prob. One more entry for the FireFly FAQ, if you would please give me permission to use your images ;-)
3Dream ( ) posted Mon, 14 July 2003 at 2:45 PM
Thanks a lot for all comments. Now, I guess , we all can use " natural hair " without problems . Wenk , my web page is having some traffic problems.
GraphicFoxx ( ) posted Tue, 15 July 2003 at 10:38 AM
stewer, wenke, that's really odd. Mine is set up like all other textures. Texture connected to diffuse and specular, with diffuse white, and value of 1; specular black with value of 1. No displacement map either. I wonder why mine turns out alright. I'm using Sr3 as well. Very very odd though.
