Look in Runtime/Dots.... and see if there are any listed here (where they go). cameraDot_1.cm2 Above is a file name sample. If they ain't there you may need to re-install to get them, or from someone else if that is not a violation of file distribution. If they are there and do not show in the Studio you may still need to install again. Don't know why they would not show. A work around is to save camera settings to your Library.
The only way I can get the Camera Dots to show up reliably is to select one of the cameras (in the pull down list below the working window) first. Then I can bring up the Camera Dots immediately, no problem. Other times, when a figure or prop is selected, all that wants to display are the Pose Dots...just one of Poser's little quirks ;) (Poser4 on an iMac, BTW)
Does anybody else have the problem, and a solution for, the phenomenon whereby the camera dots will not show up? I get the Pose Dots, and when I open the file menu and choose camera dots, they simply will not appear. Aaargh!
