Fri, Jan 24, 11:04 PM CST
Subject: Problem with Camera Dots in Poser 4 on a Mac
pookah69 ( ) posted Sat, 19 July 2003 at 2:50 PM ยท edited Sat, 18 January 2025 at 10:33 AM
Does anybody else have the problem, and a solution for, the phenomenon whereby the camera dots will not show up? I get the Pose Dots, and when I open the file menu and choose camera dots, they simply will not appear. Aaargh!
Don ( ) posted Sat, 19 July 2003 at 3:36 PM
Look in Runtime/Dots.... and see if there are any listed here (where they go). cameraDot_1.cm2 Above is a file name sample. If they ain't there you may need to re-install to get them, or from someone else if that is not a violation of file distribution. If they are there and do not show in the Studio you may still need to install again. Don't know why they would not show. A work around is to save camera settings to your Library.
mateo_sancarlos ( ) posted Sat, 19 July 2003 at 7:48 PM
Don't use the file menu; click on the name above the dots to get UV or Camera dots instead of Pose dots (assuming you confirm Don's instructions first).
lesbentley ( ) posted Sat, 19 July 2003 at 9:05 PM
I use a PC, and sometimes have trouble selecting the camera dots. I find if I click on the track ball icon thingie first, I can then select the camera dots.
Patricia ( ) posted Sun, 20 July 2003 at 1:32 AM
The only way I can get the Camera Dots to show up reliably is to select one of the cameras (in the pull down list below the working window) first. Then I can bring up the Camera Dots immediately, no problem. Other times, when a figure or prop is selected, all that wants to display are the Pose Dots...just one of Poser's little quirks ;) (Poser4 on an iMac, BTW)
doozy ( ) posted Sun, 20 July 2003 at 8:28 AM
This problem happens to me just after a render. It takes a while before I can choose camera dots. Selecting the camera first will help, as Patricia said.
lesbentley ( ) posted Sun, 20 July 2003 at 2:34 PM
Clicking on the track ball will select the camera currently in use, and is quicker than using the dropdown menu.
Patricia ( ) posted Sun, 20 July 2003 at 9:10 PM
I wonder how long it's going to take me to retrain myself to click on the trackball--it's more effecient than using the drop-down, but will probably be the instigator of many a "DOH!" while I get habituated to using it ;)
