Wed, Feb 5, 3:58 AM CST
Forum Moderators: Staff
Subject: Odd Joint Set-up Problem: Help!!
noggin ( ) posted Tue, 22 July 2003 at 8:31 AM ยท edited Wed, 05 February 2025 at 3:55 AM
I've got a really odd problem with a joint set up_ I've never had before. The joint in question is a fairly complicated join between two sections of an organic model. I've had to use spherical falloff zones in the x/y and z rotations. 'bend' is checked in both body parts. I've basically copy/pasted the parameters for the inner and outer MAT spheres so that the setup of these is the same for x/y/z rotation (so facets included/excluded should be the same) The Y & Z rotations work fine and the joint bends smoothly as expected. However on applying X rotation the seam comes apart as tho not welded (although it obviously is for the other two parameters). Ive tried all sorts of variations and adjustments to the fall-off zones without success. Has anyone ever experienced this? Is there a solution or will I need to rebuild the bone structure from scratch again? Thanks in anticipation Nigel
_dodger ( ) posted Tue, 22 July 2003 at 9:21 AM
I've had the problem with curve dials. If you have curve dials try setting them to 0 and seeing if it works better.
noggin ( ) posted Tue, 22 July 2003 at 9:32 AM
Hiya Dodger. I'll certainly have a look at that but I'm pretty certain it won't be that as I didn't include those_ but my Poser has been acting a bit flakey recently so it may have snuck them in without me being aware. I'll reset the joint rot order and see what that does. Nigel
noggin ( ) posted Wed, 23 July 2003 at 8:07 AM
Nop it wasn't that Dodger! Rather than fiddling about any longer I decided to scrap the pre-existing bones and build a new set_ no problem whatsoever.. so I conclude this was a glitch (small malevolent beastie that lives under one of the camera buttons on the Poser interface, and comes out occasionally with a large silver spanner..and chucks it in to the works....its rumoured that owing to the larger number of 'rooms' in the Poser5 interface a large extended family was able to move in prior to the release of this product.)
_dodger ( ) posted Wed, 23 July 2003 at 9:13 AM
That would explain it. Having P 4.0.3 I have no bones. I'm all rubbery and snail-like instead.
nomuse ( ) posted Wed, 23 July 2003 at 1:16 PM
You are an invertebrate Poser user?
_dodger ( ) posted Wed, 23 July 2003 at 3:26 PM
mmmyeees.
nomuse ( ) posted Wed, 23 July 2003 at 3:40 PM
That joke hardly works these days. No-one can even spell "Inveterate," much less know what it means.
noggin ( ) posted Wed, 23 July 2003 at 4:23 PM
Worked for me!! LoL!Dodger an obstinate a-skeletal? or even habitually spineless?
_dodger ( ) posted Wed, 23 July 2003 at 9:10 PM
Attached Link: http://www.xfx3d.com
Nope, just rubbery. We boneless people prefer the term 'cartilaginous.' BTW, I know what 'inveterate' means, I just didn't know that's what you were punning. But, in fact, I am quite the veterinarian B^) Mollusc rights!
