Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
I misread the thread as Vampire Feet! :0) To answer the question, you could try creating a morph target for the teeth using a 3D modelling Application, tricky when it's in the mouth. I've only used Amorphium 1.0 and I couldn't select a tooth with that. If you create a sharp tooth and parent a couple to to the head, I don't believe it will move with the mouth.
How can I made a vampire teet in Poser on my caracteres?
