Fri, Nov 15, 12:50 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 9:11 am)
Subject: Vampire teet
Carolekara ( ) posted Fri, 25 July 2003 at 2:45 AM ยท edited Fri, 15 November 2024 at 12:50 PM
How can I made a vampire teet in Poser on my caracteres?
sabretalon ( ) posted Fri, 25 July 2003 at 3:54 AM
Teet? I would assume teeth? I have seen some in freebies for V3
hauksdottir ( ) posted Fri, 25 July 2003 at 4:25 AM
Actually, "vampire teats" conjure up an amusing image of mama vampire feeding her young fresh warm blood from 6 nipples. Carolly
brandonc ( ) posted Fri, 25 July 2003 at 4:38 AM
lol
smiller1 ( ) posted Fri, 25 July 2003 at 4:55 AM
I misread the thread as Vampire Feet! :0) To answer the question, you could try creating a morph target for the teeth using a 3D modelling Application, tricky when it's in the mouth. I've only used Amorphium 1.0 and I couldn't select a tooth with that. If you create a sharp tooth and parent a couple to to the head, I don't believe it will move with the mouth.
hauksdottir ( ) posted Fri, 25 July 2003 at 5:59 AM
Hawktoey does have vampire teeth in Freestuff. I think they are for the milkids, but ought to work for anybody with some widgeting. I'm pretty sure that Traveler made teeth morphs, too.
KaraCarole ( ) posted Fri, 25 July 2003 at 6:26 AM
Thank but I just start in Poser 5
gryffnn ( ) posted Fri, 25 July 2003 at 6:53 AM
Hi, P5JudyMagic in my store here has a full set of 15 teeth morphs that include fangs and buck teeth, letting you adjust the upper or lower teeth placement in any direction, even side-to-side, or hide some or all. (Lots of other features too) P5DonMagic will have them too. HTH - Elisa/gryffnn
