Mon, Feb 10, 10:21 PM CST
Subject: Poser5 --- weird !
Himico ( ) posted Sun, 27 July 2003 at 11:28 PM ยท edited Mon, 10 February 2025 at 12:32 PM
After importing a background picture, we deleted it, and it disappeared.
However, Poser5 is searching for the background picture every time when we try to render, when we open material room, and also when we try to use materials.
queri ( ) posted Mon, 28 July 2003 at 12:31 AM
Happened to me too-- all of a sudden. Go and select the appropriate jpg when it whines about it-- it will shut up-- I hope, it did for me-- and it won't render. Emily
c1rcle ( ) posted Mon, 28 July 2003 at 3:49 AM
When you hit the render button poser will load all the textures into memory that you've added to your scene, including the ones you decided not to use in that render. What makes things difficult is if you delete a texture & poser still has it in it's list of stuff to load at render time, it'll throw a fit if the texture isn't where you told it to load it from. The best way round this until CL creates a way to unload the textures is to save the scene, close & restart poser then render, that way only the textures you want will be loaded.
queri ( ) posted Mon, 28 July 2003 at 4:07 AM
I did close it down and re-open-- no luck, the darn proggie still wanted "sunset at sea." That's the point I gave up and gave it "sunset at sea". I had really hoped that this texture problem would get cleared up with P5 but not so far. Emily
c1rcle ( ) posted Mon, 28 July 2003 at 4:21 AM
now that is weird, maybe it's saving the reference into the pz3 as well. quick rummage round with a text editor & the word NO_MAP will fix it once & for all, shame we still have to do this sort of thing by hand tho.
smiller1 ( ) posted Mon, 28 July 2003 at 6:27 AM
Use the material editor to modify the background. You'll see the texture there & you can remove it.
Himico ( ) posted Mon, 28 July 2003 at 7:54 PM
I also did close it down, turn off computer, and re-open-- no luck.
Emily,
@What should I do, after selecting jpg ?
smiller1,
How can I use the material editor to modify the background?
Thank you
HimiCo.
smiller1 ( ) posted Tue, 29 July 2003 at 2:25 AM
I don't have Poser 5 handy, so I'm going to do this from memory. Hopefully someone will fix any gaps I may leave.... 1. Click the material tab -you probably knew that :0) 2. Click on the object list twistie (that's the triangle next to the word object in the top left of the material window). 3. Select Background <<<- relying on memory here, maybe another word that means Background. 4. Now you should see the node (that's a smaller window within the material window) that represents the background picture. 5. You can either modify the node so it shows no picture or delete it. If you can't see the node, check it's not outside the window by using the scroll bars. It's just like MS Windows but the graphics are different. If you still can't find the node, work your way through every material in every object till you find the culprit node and amend/delete it. I used to get a similar problem (frequently) in Poser 4 and the only way to fix it was to manually edit the PZ3 file. Good luck & let us know what happens.
KarenJ ( ) posted Tue, 29 July 2003 at 6:34 AM
This happened to me with Poser 5. It saved it into the PZ3 even after deleting it in the material room. I ended up opening the .pz3 file in Wordpad, searching on the .jpg name and killing the lines in which it appeared (I think it was in there twice.) Then saved the file as a different name just in case I totally killed the .pz3, LOL. It got rid of the pic, but the window was still too large, I couldn't be bothered to go back in and fix that though. The other thing that would fix it is to create a 6x6px .jpg or .gif in a colour to match your background and import that as a new background, but obviously don't change the window size when it offers.
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan Shire
queri ( ) posted Thu, 31 July 2003 at 6:50 PM
Well, the easiest thing was giving it the darn texture it wanted-- I still got the render I asked for-- against black, no background. I've given up trying to make Poser make sense. You know, it's so irrational, I'm wondering if we're not dealing with artificial intelligence gone mad. It's certainly as un-predictable as your average sociopath. You know it's gonna screw up, but tryng to guess when and why is impossible. Emily only half kidding.
