You guys all think this is Bryce, Man this is incredible, I keep looking at it and it seems like a painting out of a museum! I keep thinking if I scroll down I'll see the Bryce version of it. Its so Beautiful! I want to hang it on my wall. Sam you've outdone yourself on this one, its so good. I may need to see the wireframe to be convinced this is Bryce. Ok, if my jaw hangs open any longer flies are gonna get in my mouth. Angela
Thanks for all the encouragment. Im not sure how much more I can do on this as it
s slowed my PC to a crawl and I havent added one light yet. I was going to darken it down a bit and have lights between the houses but I think my cpu may melt first. Any hints for keeping a biggish pic managable while I work on it? I like the idea of furled sails. Back to the meatblls I suppose. I purposefully chose this wave set to add to the calm feeling of evening I was aiming for. I think I
ll stick with it.
Jeez! I hope this isn't a challenge entry......I'm struggling as it is..... The waves....you could try rotating the .mat about 90 degrees and have them goind from left to right, which would fit in with the direction of the sea....0.0p The Bryster
Excellent. a true masterpiece. I think the ship doesn't need any sailors on it. It would look much more peacefull without them. I agree about the water. It's to repetitive. I don't know if scaling down will make it look much better, maybe adding some variation to the bumpmap in the DTE and a slightly lower bump-setting would help more. There's something about a few parts of the models that doesn't seem right. The chimneys and some of the roofs look like they are oversmoothed. If the houses are imported meshes you should try setting the smoothing lower then 90 degrees (preferably 89 degrees). It's very subtle, but being a perfectionist I noticed it immediately.
(_/)
(")(")This is Bunny. Copy and paste bunny into your
signature to help him gain world domination.
Lin: Great title! Really...!
Been working on this for a couple of days. Still have some more things to add, seagulls, maybe some sailors on the boat. Then I need to sort out some of the textures and mess with the lighting. Quite pleased with it so far. I think there may be a second pic in this if I crop and render just the dock area where the horses and little poser bods are.
