Thanks for the info everyone. BUMMER. Thanks, Spider, I'll give that "thought process" a try. It's not the end of the world, just something I'll have to get used to. Wouldn't be so bad if that were the only 3D app I used, but Bryce, Poser, Max, etc. all use the "NORMAL" axis setup. Thanks again, Tim
Came across another view quirk ... Vue does not follow conventional AXIS setup. Every other 3D app I have used has the Y-axis as up/down ... NOT the Z-Axis. Is there any way to change the naming convention in Vue so that it is correct? Thanks, Tim
