Tue, Feb 4, 9:42 PM CST
Subject: Is it possible to change default AXIS in Vue?
timoteo1 ( ) posted Fri, 01 August 2003 at 7:32 AM ยท edited Tue, 04 February 2025 at 9:34 PM
Came across another view quirk ... Vue does not follow conventional AXIS setup. Every other 3D app I have used has the Y-axis as up/down ... NOT the Z-Axis. Is there any way to change the naming convention in Vue so that it is correct? Thanks, Tim
gebe ( ) posted Fri, 01 August 2003 at 8:25 AM
No , you cannot change it. Vue is not the only 3d application with Z for "up/down", Carrara is too and for sure there are others:-)
spider1313 ( ) posted Fri, 01 August 2003 at 9:01 AM
Truespace does as all well...Actually, I, too had a hard time with this when I first came over to VUE, but now I just think of the 'Z' in azimuth, then I think 'sky', then I think UP, and THEN I'm alright...;-)!! ==steve
gebe ( ) posted Fri, 01 August 2003 at 9:04 AM
My old CorelDream too.
spider1313 ( ) posted Fri, 01 August 2003 at 9:09 AM
Hey!! Who put that 'all' in front of 'well' in my post? C'mon now 'fess up...hehe?!? ==steve
timoteo1 ( ) posted Fri, 01 August 2003 at 3:11 PM
Thanks for the info everyone. BUMMER. Thanks, Spider, I'll give that "thought process" a try. It's not the end of the world, just something I'll have to get used to. Wouldn't be so bad if that were the only 3D app I used, but Bryce, Poser, Max, etc. all use the "NORMAL" axis setup. Thanks again, Tim
