Fri, Jan 24, 7:56 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: Anton's egyptians
Porthos ( ) posted Sat, 02 August 2003 at 11:37 AM · edited Fri, 24 January 2025 at 7:31 AM
I get a screwed up clothing when I conform to Mike! IK is off, and I'm using P4 4.03. Any ideas what's happening. Vicky's conforms ok!
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD 7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
JetM ( ) posted Sat, 02 August 2003 at 11:46 AM
Havn't used it for awhile, but I think you're supposed to parent the figure to Mike, not conform it. It had something to do with the skirt. Do you still have the readme?
Porthos ( ) posted Sat, 02 August 2003 at 11:56 AM
Yes I've read the readme and it does say that conforming causes the shins to over rotate! I guess I must parent the skirt! Thanks!
AlleyKatArt ( ) posted Sat, 02 August 2003 at 12:35 PM
The skirts aren't meant to conform. The male clothes aren't that great, but the female one can conform if you use the short transmap.
Kreations By Khrys
Momcat ( ) posted Sat, 02 August 2003 at 1:38 PM
The female one conforms just fine. I'm using on Stephanie Staxx right now. You just need to run it through the Tailor first for Steph though, or the hip/abs don't fit right. Use the body handles (via the shin parameter dials) to pose the skirt.
Porthos ( ) posted Sat, 02 August 2003 at 3:03 PM
Thank you! I found that Vicky conforms and Mike's need to be parented! Trying to get the hang of posing it! :P
Porthos ( ) posted Sat, 02 August 2003 at 3:20 PM
I think I've got it! Not perfect but it's a start! ^-^
AlleyKatArt ( ) posted Sat, 02 August 2003 at 3:23 PM
I find the male skirt rather clumsy, at best. However, you've got it looking /good/.
Kreations By Khrys
Lyrra ( ) posted Sat, 02 August 2003 at 4:23 PM
well its an awkward piece of clothing to begin with ... you're not really meant to move around that much in it
AlleyKatArt ( ) posted Sat, 02 August 2003 at 4:28 PM
True. But it's clumsily built, as well. It doesn't scale, at all, and if you try, you get horribly results. The idea was a good one, but the way it was done wasn't.
Kreations By Khrys
bijouchat ( ) posted Sat, 02 August 2003 at 8:22 PM
hrm, idea floats through my mind to make it into a one piece obj and try it in the P5 cloth room.
Jenny_Lea ( ) posted Sun, 03 August 2003 at 2:17 AM
keep in mind that the eegyptian skirts are constricting and were never used for action like the second pic poose ^_^ just a point not a critisim
