Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 9:06 pm)
well you've got a problem with that head. I suggest that, like Wookie said, you ditch Don's head and use Mike's already attached head. It will save you many headaches further down the line. So yes .. you'll lose the shaping you've done with it, BUT! since Don's mapping is like Mike's, you can use the texture on Mike. Most of Mike2's morphs are set up as FBM (full body morphs) which means that you use the master controls in the Body section of the figure to change them. However, if you select an individual bodypart you'll see a list of morphs (most of which are in FBMs). So if you click on Mike's head you'll get all of his many and varied facemorphs to turn him into Arnie
