Grey, I appologize, but I got about 50 e-mails with this same question, and I have to answer the same every time. Here's a little note that I have included in the retail version of this file. Extremely important If you do not have a program that is able to decompress .rar based files you Must download one of the following programs in order to extract the package files. For Windows: Winrar at http://www.rarlab.com/download.htm For Mac users: Stuffit at http://www.stuffit.com/mac/index.html Enjoy, If you are still having trouble E-mail me at RobertxMcCarthy@Earthlink.net or contact me Via AIM: RobxMcCarthy
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1379349
I assume this is the "fixed" version?? Don't know if you saw them or not, but I did post a couple of pic's at the other forum. See link above. I will use your revised ones and do another.Yes, that's something that Rhino did on the export. It's to conserve memory. If you are rendering a lot of those grasses it can cause a memory overload if the model is not divided. Poser can not handle divided models? Can anyone else confirm this and try to load the 78k poly model in poser? 78k polys might just be too much for your system perhaps?
Attached Link: 3dwin convert .3ds to any format
Perhaps try converting the high poly one to obj format, you can do that with 3dwin found here.I have a 1.7ghz processor, with 512 mb DDR Ram, Pentium IV and Windows XP Pro. Poser can handle pretty huge files on my system. The V3 .obj is over 8 mb and I have some texture files over 22mb. I could open the 78k poly model in Vue without any problem....in fact I rendered an image with it and the sprouts in Vue and it looks very good! Since this isn't the Vue forum, I didn't post it :) The problem loading the 78k poly in Poser could be a Poser issue and most likely a Poser issue with .3ds divided models. My experience is that Poser seems to like .obj files better than .3ds :) The only problems I've ever had with Poser have involved .3ds files. I'm not sure if there is any difference in the quality between the two. Based on what I've seen, if your price is $15, I would probably buy these to use in Vue.....and Poser where possible. Can you address the "this .3ds format is obsolte" message that I got in Vue? Are you using an older version or do I simply need to install that update? :) Also....textures....are there any???
Ornlu, that gadget (3dwin) works pretty good! I exported as an .obj and that newly created 16.8 mb grass now opens fine in Poser 5 :) However, it is all one piece. Is there any way to get the seperate parts in an .obj? I followed the instructions for povray when checking the options boxes. Any tips are appreciated.
Textures are not really needed, and add to the render time, you can use simple grey colors. Did you read my reply above, there's a link to 3dwin that will allow you to convert it into an obj format. This will work better, but the file size is bigger so I couldn't format them this way. OBJ is probably a better format anyway. YOu can just slect a bunch of files to convert to obj, but be warned these files will be much larger than the 3ds form.
Attached Link: Free High Quality Grass
![file_71549.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_71549.jpg)
Hello I recently fixed a freestuff upload I have to work for poser. If anyone could attempt to import the files into poser and render some scenes with a character or two for me, I'd be eternally grateful. I am completing a commercial pack, and need to know how well this works in poser. Thankyou sincerely for your help.
