Forum Moderators: Staff
You can just pinch a taperY channel from any cr2 and paste it into the actors in your own cr2. An easy way to add a channel to all the actors in a file is to do a global search and replace of;
channels
with;
channels
[new channel]
Here is what a taperY channel looks like:
taperY taper
name taperY
initValue 0
hidden 0
forceLimits 0
min -100000
max 100000
trackingScale 0.04
keys
static 0
k 0 0
interpStyleLocked 0
P.S. you can put taper channels in pp2's as well as cr2's, this is a quick way to make some new primatives.
I hear that Bloodsong has written a book about Poser, I don't know how deeply it goes into cr2 editing, you could drop her a line by IM and ask. (Bloodsong, perhaps you could post a list of contents, or some info on your book in this thread?) Some stuff on the structure of cr2 file format in the tutorials section of this site: http://home.carolina.rr.com/kattman/ Other Poser sites you may find usefull. ERC/EMC related: http://64.38.105.73/erc_download.html http://www.rbtwhiz.com/rbtwhiz_ERC.html http://www.nerd3d.com/Tutorial/SuperMorph.htm readScript: http://www.rbtwhiz.com/rbtwhiz_rScript.html General: http://www.3dlinks.com/tutorials_poser.cfm http://www.cocs.com/poser/ http://www.3dmenagerie.com/goodies/tut/index.htm http://www.shar3d.com/tutorials_index.htm
heyas; the taper doesn't have any fancy internal code, it is just a plain dial. poser knows how to use it based on its type/name. to answer your specific question, yes, the cr2 is completely dissected in my book. also covered are advanced cr2 editing techniques like erc and geom swapping, putting stuff in, taking stuff out, etc. the rest of the stuff? let's see, there's your basic morphing concepts, how the magnets and grouping tool are supposed to work; joint parameters in all their gory details; the techie file stuff; and then general modelling tips and tricks. some info on how to use p5's cloth and hair to good effect in your designs.
Speaking about joints. You'd laugh if you saw how I tear into the Joint Editor to make my poses look natural. Even though I like the result, the figure is good for nothing else afterward. I guess there's a way to reset the original Joint Parameters, Falloff Zones and Bulges, but I haven't found it yet. Any suggestions? Yup, I do a lot of backups. Steve
"I guess there's a way to reset the original Joint Parameters" You can make a pz2 to restore the original Joint Parameters. One way to do this is to make template pz2 file listing all the actors, and including a 'channels' section for each, then use Morph Manager 4 to copy all the Joint Parameter channels from the cr2 into the template. First you need to load a pz2 (any pz2) into the same Morph Manager window you will use load the cr2 into, this forces MM4 to display all channels, if you don't load a pz2 first it will only display morph channels. Here is a snippet from a pz2 template to show you the format, don't forget to add a closing brace to the end of the file.
version
number
actor BODY
channels
actor hip
channels
actor lToe
channels
I made the template easily enough in MM4 but I can't figure out how to get the DAZ M2 default JP's into it. Tried to use a text editor, but That cr2's a bit beyond me at this point. Steve Oh, I ordered Bloodsong's book. I'll catch up to some of you pretty soon. But looking over the threads and tuts its seems a lot of Poser will remain a mystery or is just plain arbitrary.
Using Poser4 Pro I've made a few figures in the setup room. What I can't find information on is how to get Taper Y into the channels processes of the cr2 and get the associated parameter dial. It's not a morph target since there's no deltas. Is there a quick and easy way to do this that I'm overlooking? What are the best books on understanding cr2's?
