Sat, Feb 8, 3:49 PM CST
Subject: What's the deal with *.mtl files from an exported poser object
HAE_Inc ( ) posted Wed, 20 August 2003 at 3:59 PM · edited Sat, 08 February 2025 at 3:11 PM
Hi, I've been just getting on to exporting obj files from poser recently and I was wondering what the story is with the mtl file that exports with it. I'm thinking that i may as well delete it because i dont have any other rendering programs which it seems like theyd only be used in those other types of programs as opposed to poser. Thanks
Little_Dragon ( ) posted Wed, 20 August 2003 at 4:25 PM
That is the .obj file's accompanying material file, which, among other things, tells various 3D applications which textures are applied to the object's materials.
mit123 ( ) posted Wed, 20 August 2003 at 4:27 PM
Ahh, so how do you use it? I couldn't find it in the maual, see my Glock thread below:)
onnetz ( ) posted Wed, 20 August 2003 at 4:38 PM
you cant use it per say.. your 3d program either does or it doesnt....
Handle every stressful situation like a dog.
If you can't eat it or play with it,
just pee on it and walk away. :-)
I wouldnt have to manage my anger
if people would manage their stupidity......
SAMS3D ( ) posted Wed, 20 August 2003 at 4:46 PM
Online Now!
Just what onnetz says....applications like Vue and Bryce use it for example like Vue, you have a summary of materials, and if you don't have the .mtl file you can not see what the names are ie. head arms eyes...etc.
Little_Dragon ( ) posted Wed, 20 August 2003 at 4:47 PM
You keep the .mtl in the same folder as the .obj. If your application can use .mtl files, it'll read the .mtl automatically when you load or import the .obj.
HAE_Inc ( ) posted Wed, 20 August 2003 at 5:14 PM
So, you're telling me I shouldn't delete it Thanks Again
mit123 ( ) posted Wed, 20 August 2003 at 5:15 PM
Ok, I'm with you so far but without wanting to sound to stupid, how do I get the texture and bump file to work properly with the .obj? I tried the materials room but I kinda didn't know what I was doing :)
dan whiteside ( ) posted Wed, 20 August 2003 at 8:12 PM
What app are you using? Somebody here will probably know if it supports .MTLs. Also a .mtl only stores solid colors, image textures and surface property values. If there's not any nodes hooked up to a image texture you won't get any in the .MTL. You also have to have the bump channel hooked to a bump image texture for bump maps to be included. P5's "math" textures and displacements are an internal part of Poser and can't be exported. HTH; Dan
mit123 ( ) posted Wed, 20 August 2003 at 8:22 PM
Thanks Dan, I just worked out where I was going wrong, the prop I was working on had two seperate parts that needed texture and bump maps to be applied to both. Thanks all for the pointers :)
