Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 2:19 pm)
you cant use it per say.. your 3d program either does or it doesnt....
Handle every stressful situation like a dog.
If you can't eat it or play with it,
just pee on it and walk away. :-)
I wouldnt have to manage my anger
if people would manage their stupidity......
What app are you using? Somebody here will probably know if it supports .MTLs. Also a .mtl only stores solid colors, image textures and surface property values. If there's not any nodes hooked up to a image texture you won't get any in the .MTL. You also have to have the bump channel hooked to a bump image texture for bump maps to be included. P5's "math" textures and displacements are an internal part of Poser and can't be exported. HTH; Dan
Hi, I've been just getting on to exporting obj files from poser recently and I was wondering what the story is with the mtl file that exports with it. I'm thinking that i may as well delete it because i dont have any other rendering programs which it seems like theyd only be used in those other types of programs as opposed to poser. Thanks
