Mon, Jan 6, 8:03 PM CST
Subject: Cloth Room Afficionados
dirk5027 ( ) posted Wed, 27 August 2003 at 8:16 AM · edited Mon, 06 January 2025 at 8:01 PM
could someone talk me through this?? I'd like to have mike on a chaise, nude with genitals on, I would like a cloth draped over the hip and genitals, with the fabric close to the skin giving the outline of the genitals (sensual but not nude) Is this possible? I have tried tutorials with no luck.
PhilC ( ) posted Wed, 27 August 2003 at 8:31 AM
Yes this is possible. What did you do and what were your results? I say that because this may be a better approach that repeating the info in those tutorials.
dirk5027 ( ) posted Wed, 27 August 2003 at 9:03 AM
Oh boy Phil , i tried it so long ago, not sure what I did really.. I got disgusted and gave up, I do remember my square for the cloth, kept going to the ground, no matter what I did
randym77 ( ) posted Wed, 27 August 2003 at 9:08 AM
I highly recommend Nerd3D's tutorial: http://www.nerd3d.com/Tutorial/Cloth/Cloth.htm If your cloth is falling to the floor, you probably forgot to pick a collision object. Don't give up, learning the cloth room isn't that hard, and it's worth it. Dirk, what you want to do is very possible, and should be fairly easy.
PhilC ( ) posted Wed, 27 August 2003 at 9:49 AM
In the cloth room just set the cloth plane to collide with the figure and let it fall under gravity.
dirk5027 ( ) posted Wed, 27 August 2003 at 11:55 AM
I just followed that tutorial to the letter, and it still didn't work...thanks anyway If I had made this room..Load figure..load cloth..clothify..pick body part to collide against..then click GO your done I'm also not making an animation, so I don't understand why I am worrying with frames
PhilC ( ) posted Wed, 27 August 2003 at 12:26 PM
Could you amplify "It didn't work"?
  • Nothing changed, the scene remained exactly as before?
  • The cloth fell to the floor?
  • It looked as though it was trying to do something but got stuck?
  • The figure got bored and walked off for a pint?
Wondering why you are asked to calculate frames for a static pose is not an unreasonable question. It took me a while to get my head round it also. What I found was that Poser needed to calculate where the cloth needs to be, its not like conforming clothing. It does this in a series of steps or frames. If we want to drape cloth over the figure then the form that the cloth will take will be dependant on how its applied. Fall under gravity? Pulled across from the side? In either case motion is involved, and the results will vary. You can not just tell Poser to "Drape the cloth" . The gnomes that make it all work will be scratching their heads saying, "Drape? which way, how?" If you don't tell them then THEY all go down the pub with the result that "it didn't work".
dirk5027 ( ) posted Wed, 27 August 2003 at 12:43 PM
first off Phil, I really appreciate your time for bothering with this for me.. Ok it kept dropping to the ground and actually kept going beyond the ground plane.. so i thought hhhmm what if i parent it to his body so i got this which is bad but much better than I was getting, the black line is where i would like it to flow (pay no mind to anything, this was a test guy)
dirk5027 ( ) posted Wed, 27 August 2003 at 12:47 PM
not sure if that flow of the cloth is possible, i might have to come up with another idea
randym77 ( ) posted Wed, 27 August 2003 at 12:51 PM
The frames are a key part of the cloth room. I'm new to Poser and know nothing about animation, so it took me awhile to figure out that part. But I did it, and if I can, anyone can. :-) Basically, you can't drape cloth without creating an animation. Yes, even for a still image. After you run the calculation, go back into the pose room and use the animation slider to run through the animation you've created. (If you're like me, you've probably never touched the animation menu before. But you have to, for cloth.) If you're on frame one, it may look like it didn't work. But move through the other frames, and you should see the cloth start to drop into place. When the cloth is where you want it, stop and render that one. Also, for what you want to do, I would choose "Figure 1" (or whichever figure Mike is) for the collision object, rather than a particular body part.
PhilC ( ) posted Wed, 27 August 2003 at 12:58 PM
OK Parenting the cloth to the figure is good because once the clothfying bit is all done you may want to move him to another part of the scene. By parenting, the cloth will follow him and not get left behind. Parenting/Not parenting makes no difference to the cloth calculation.
In the cloth room what are you selecting the cloth to collide against? Are you just selecting a few body parts? If so I found it best to select the whole figure then click the option boxes to discount the head, feet or hands.
Can you give a screen shot of the scene before going into the cloth room. Is the cloth hovering above the figure? Is it touching any part of it?
How many frames are you using? (I suggest use 30). Are you using any drape frames?(I'd probable not use any in this example). Are you selecting the "Drape from zero" option? (Probably best not but will depend on what you show me as your starting point)
Back-at-ya :)
dirk5027 ( ) posted Wed, 27 August 2003 at 1:11 PM
I selected hip and figure 2 which is posable genitals, the cloth is hovering above the figure, moved it there, if i didn't that's when it went straight to the ground. simulation range 1 and 30 drape frames 10 and i had drape from zero pose checked, hope that helps
PhilC ( ) posted Wed, 27 August 2003 at 2:53 PM
Select it to collide with all figures. I can not see if it will hit the head, feet or hands so leave them in for the moment. I would not bother with the drape frames. If I've understood you right and the figure is in the above pose throughout then do not use "drape from zero". Add in the cloth self collision option. Possibly increase the simulation frames to 45 to allow the cloth to settle.
Give that one a go :)
dirk5027 ( ) posted Wed, 27 August 2003 at 3:26 PM
i'll give that a go thanks again
PabloS ( ) posted Thu, 28 August 2003 at 6:49 AM
PhilC ( ) posted Thu, 28 August 2003 at 7:09 AM
waves to PabloS
I see you sneaking into the back of the class.
tisk, tisk late again :))
PabloS ( ) posted Thu, 28 August 2003 at 7:16 AM
Shoot! Busted! :-)
dirk5027 ( ) posted Thu, 28 August 2003 at 7:37 AM
Yep Pablo your late for class :) Thanks again for all this Phil, I have a sick mother,looking after her, not sure if i'll be able to get back to trying this out for a few days,but thanks again.
dirk5027 ( ) posted Thu, 28 August 2003 at 7:44 AM
Sorry randym77, thanks so much for your input also, I really appreciate it.
randym77 ( ) posted Fri, 29 August 2003 at 6:39 PM
Sorry to hear your mom is sick.
Looks like you got the cloth to drape. You're getting there!
It might be tricky to get the cloth to fall exactly the way you want it, along his leg that way. It may slide all the way to the floor, because of his position. If so, try selecting a frame before the cloth slides to the floor. If it doesn't look exactly like you want it, you could always use magnets to pull it into place.
