Then you're apparently doing something wrong. Or your copy of Bryce is bewitched. I just tried rotating a spotlight and it goes wherever I turn the Rotate ball. Unless... When you rotate the spotlights, are you certain you pull the right axis? No offence intended, but I found myself many times pulling one when I wanted another. What you describe sounds a lot like you're rotating the lights just around the Y axis. BTW, holding down CTRL and clicking on one of the axis dots (the ones that sprout X,Y and Z when you hold your pointer over them) around the light (or any other object) will give you a small two-way arrow and will enable you to rotate it however you choose. HTH.
-- erlik
This might be an old topic but something is driving me crazy I am ready to light an indoor scene (a room) I place my spotlights,(4 in a row ) and then I try and adjust the position using the editor rotate bally thing..... But no matter how I turn or twist them (individually, or grouped) they always position (Or go back to) the same "default" position I hope someone out there knows what i am talking about and had an answer for me cuz its really making me nuts. roch222
