Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
Hey Clarissa, I have a Jennifer texture for Bryce that includes a sweaty look (a Bryce texture combined with an imported poser texture). Go to http://www.pussreboots.pair.com/poser/textures.html Click on Jennifer. Then all you have to do is replace my poser texture with your poser texture. Voila. Sarah
If you want to create the sweat yourself you would first go to an image editing program, make an alpha channel of the water beads using a poser figures uv template.(keep in mind the white areas are affected) When you import your poser model into bryce go into the material editor and load your alpha channel as component "B" then assign this component to the specularity channel. mess with numerical input to get different levels of specularity.(wetness)p.s. You may want to ungruop the poser model and regroup and create families for the hair/eyebrows, figure, and clothes seperately, this will allow you to easily place your created textures on each individual group. Hope this helps also.
Sorry bout the ill sounding title, thought it'd get your attention though. It really is appropriate to my question!!! =) My question is, is it possible to create a look of sweat on a poser figure? Either in Poser or Bryce (cause the poser figure is in my bryce scene!) Maybe if anyone is brilliant enough to do this they could upload a small picture of it? Thanks everyone for all your help, Luv Clarissa!
