Tue, Dec 24, 12:21 PM CST
Subject: A few simple animation questions
eqplayer ( ) posted Mon, 24 July 2000 at 1:12 PM ยท edited Wed, 31 July 2024 at 12:00 PM
  1. How do I drop an entire animation to the floor? For example, even though my figure was posed on the floor, and animated there, when I save the animation and reload it later, the figure hovers a little bit off the floor. If I drop the first frame to the floor, then when I hit play the figure slowly rises. Do I have to manually go in and drop every frame to the floor? 2. Is there a way to save just the last few frames of an animation? Can I delete say the first 30 frames in a 40 frame animation and keep the last 10? 3. Also, how do I make the ground visible? If I have a background different from the ground, both still look the same. Also, is there a way to raise the ground UP, that would solve the problem in #1. I've looked in the manual, and I can't find the answer to any of these questions...Any help would be appreciated.
bergerac ( ) posted Mon, 24 July 2000 at 4:12 PM
I still work with Poser3, so I don't know if this will be of any use, but here are some suggestions: 1. I'm not too sure about this one, but at most you should only have to hit "drop to Floor" at every key frame. 2. There's a slider called "Play Range" at the bottom of the animation palette that you can use for this. 3. In Poser3 the ground plain is more or less like a prop. You make it visible by ticking it on the guides menu, and you can move it (Y-tran/X-tran/Z-tran) or scale it in your first frame, delete all susequent keyframes for that element and it should stay where you put it. Hope it helps. Berge
pack ( ) posted Mon, 24 July 2000 at 8:49 PM
1)No universal drop to floor. Read bulk change above. Other work around is to resample keyframes (to make less work) then click next keyframe arrow with one hand, Ctrl D with the other & step thru all the keys one by one. I've been bugging Larry W about adding this feature. 2)In AnimPalette drag arounf all beginning keys & delete. Then drag arounf end keys & copy & paste to the begining. I think also can svae pose over range of frames as well. 3)Uncheck Display/Guides/Ground Plane
Wizzard ( ) posted Tue, 25 July 2000 at 2:22 AM
egg, a quickie.... pull open the heirarchy window, click on the GROUND, close window... the ground will stay until after the render.. neat ne? 8 ) Wizzard
