Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 02 9:25 am)
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
Use a very small bevel between the top and side (thickness) when creating the object in the 2nd example. This will fix smoothing. Poser has no smoothing groups so it is trying to smooth the object between a 90% angle. That is what gives you these funky shadowed areas. This is assuming a lot of things since you don't give that much info. I don't know what is up with the first example. I hope this helps, Joe www.3-AXIS.com
off.
-- Bjarne
Stroustrup
Also, smoothing is turned off for all of the parts. There is no need for smoothing on non-organic surfaces like these (and it also avoids the infamous P5 "bubble" renders). I've tried importing the OBJ file with and without welding, with and without normals. Seems to me, by the thousand renders done of this model in Poser for testing, that Poser lighting works polygon-by-polygon instead of taking an entire surface (polygon-polygon angular relationship) into account. Smoothing does this for organics, but not in this case. Help, please!
off.
-- Bjarne
Stroustrup
Try splitting vertices in UVMapper. Usually when my props look like that a "split vertices" helps it. No matter if I have beveled it or not :o)
Thanks, ernyoka1. I will give that a try and reply on the results - please be good! ;)
off.
-- Bjarne
Stroustrup
ernyoka1, are you a man or woman? Because I'm gonna marry ya! ;0) That fixed about four or five linguering problems - especially in rendering! Leave it to UVMapper to solve all of the world's problems. Thank you very much!
off.
-- Bjarne
Stroustrup
Hehe I'm a woman, and I am not sure bigamy is allowed? ;o) Just glad it worked. It usually does the trick but it DOES make the files a little larger :o)
-- Bjarne Stroustrup
