And as I said, it's not always clothing. Sometimes it's just portions of the body mesh itself, or the whole body that doesn't import.
Create a new model and import it. Are you using Poser Pro Pack? Some old files seems not to import properly into 4.2, it seems that's a question of Poser's multi frame system. In Vue, you must click "import single frame from Poser animation" when asked for. There are several threads about that here in the Forum. http://www.renderosity.com/messages.ez?Form.ShowMessage=1435269 and others... Guitta
Gebe, No, actually, I used Poser 4 (upgraded, I think, to 4.03) before I started using Poser 5. I guess I should have said that I'm using XP, as well. I will check out the other links and such and see if those help, as well... but so far as I know, I've never gotten a message asking about single frame or animation. These are static PZ3's, and when I import them in 4.2, the only notice I receive is something about importing models as single meshes. If older models tend to be a problem, should I attempt to load the pz3's in Poser and re-save them, to see if that helps?
I notice, also, that with a lot of my presaved PZ3's, Vue has 'forgotten' the texture pathways, as well, and asks me to find the proper texture files. This could be because when I originally set up Vue, I pointed it toward a Poser 4 exe, and now I have pointed it toward my Poser 5 exe file. (I've saved my Poser 4 runtime directory to use with Poser 5, so maybe the directory structure is what's causing difficulty with that. Maybe I should reinstall P4 and upgrade it, and then point Vue to it. I really don't know.)
Okay, little update. A couple of those files in which it couldn't find textures? I opened Poser 5, opened the PZ3's and resaved them, and Vue found the textures, no problem. I have to go to work now, but when I get home tonight, I'll try to do the same thing with files that were missing meshes (like the one above,) and keep you all informed. Here's to hoping that was the problem... I think i can deal with opening and resaving all of those in P5. Thanks for your help, too, gebe!
I aim to update it about once a month. Oh, and it's free!
I recently upgraded to the Vue 4.2 Beta from the full 4.12 upgrade (in one lump sum. I did the 4.12 update, then 4.2) and after doing so, have tried to import a few PZ3 scene files that I had previously saved before upgrading. I located the Poser 5 exe file (I'm using P5 with the SR update) and everything seemed fine... except:
Now that I've upgraded, quite a few of my scenes come in missing portions of their bodies. A scene I had with two characters is missing the entire body of the second character and only showing the hair, even though the first character seems to be fine. Other files seem to now missing shins, hands, and the like. This happens whether I load them as a single mesh or not, and in some cases, are missing clothing (or portions of which) that I had placed on them. (See pic for clarification)
I should note that all of these had originally loaded fine in 4.11. I've checked and have all the requisite (poser, poser 4 and poser 5) dll's in my Vue directory, as well as the Vue.rsr... Is this a problem anyone else has had and (preferably!) fixed? If so, how? Or is my best bet to say heck with it for now, reinstall and reupdate to 4.12 and stay there?
