Must be a mac thing then. If anyone has a solution I would be very thankful. Right now the files all come in as download.ez and then won't open. Just gets a long string of code and junk if you try to click it. I used to get it that it would understand there was a zip file in there but now it doesn't do that at all. The download thing was annoying as it was cause I can't tell what is what but now the files don't work at all.
Explorer on Mac always downloaded the file as "download.ez", but I also experienced the wrong typing for a long time. As a coincidence, I just recently found out about the reason, it is partly caused by some strange behaviour of the Renderosity server, and partly by the way how IE accesses Internet Config. I made a complete description how to fix it here: http://www.renderosity.com/messages.ez?ForumID=12357&Form.ShowMessage=145546 'Hope that helps, MartinC
I use IE 4.5 on MAC. I always "download link to disk" then run through stuffit expander (never double click). Sometimes host site problems but in that case I copy thr link to clipboard, open a new window in IE & paste the link imto url & hit re-load at which time it usualy dowwnloads OK. Sometimes BebEdit will auto open the file but I just close it & run thru StuffitExpaner & all is fine.
Is it possible? I can't get the dang things to download for nothing. Maybe because I am on a Mac but I have never been able to have it work well and with IE 5 it won't work at all. Thanks
